Suspension
Old Jan 30, 2005 | 07:07 PM
integ R a's Avatar
Default Suspension
If I <U>just </U>get neuspeed coilovers for my 96' RS, will that be bad for my tires, etc. in the long run?
Old Jan 30, 2005 | 07:49 PM
BrianZ's Avatar
Default Re: Suspension (integ R a)
yes.. because you will probably go around corners much faster..
but if you drive the same, do an alignment on your car (back to factory specs on camber and toe) you should not notice a difference.
Old Jan 30, 2005 | 08:20 PM
DC2Slow's Avatar
Default Re: Suspension (BrianZ)
lol
Old Jan 30, 2005 | 10:41 PM
pubestripe's Avatar
Default Re: Suspension (DC2Slow)
if your camber is bad, then yes it will make your tires wear faster. it might be wise to invest in a camber kit and alignment with those springs.
HWKR3W
Dec 19, 2010 01:46 PM
kronikSLOW
Jan 25, 2009 08:49 PM
ThaSpitefulWun
Sep 23, 2002 01:56 PM
supratt
Jan 23, 2002 04:04 PM
99 HXagon
Dec 9, 2001 09:08 PM
