car started after it hydrolocked...
Old Jan 30, 2005 | 06:49 PM
2k1 GSR's Avatar
Default car started after it hydrolocked...
right before new years i hydrolocked my motor. i pulled the plugs and cranked the ignition and shot out all the water i could. i got new plugs and charged the battery. the car started and ive been driving it for a week. everything seems fine it just doesn't feel as powerful as before and has an awkward sound at low rpms. could anything be wrong or is it all in my head?
Old Jan 30, 2005 | 06:56 PM
daLixz25's Avatar
try starting with a compression test..
Honduh Chicken's Avatar
I fry gay turkeys
Default Re: car started after it hydrolocked... (2k1 GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k1 GSR &raquo;</TD></TR><TR><TD CLASS="quote">right before new years i hydrolocked my motor. i pulled the plugs and cranked the ignition and shot out all the water i could. i got new plugs and charged the battery. the car started and ive been driving it for a week. everything seems fine it just doesn't feel as powerful as before and has an awkward sound at low rpms. could anything be wrong or is it all in my head?</TD></TR></TABLE>
you could have a bunch of different problems, more than likley you have bent a valve slightly causing your reduced power and noise at low rpm, I'm assuming its a clacking sound... I think you could have also damaged the fuel injectors since they were wet (unlikey though) prob need a valve job and if they hit the piston then you might need a piston or two.
good luck.
btw, post pics once you take the head off.
Old Jan 30, 2005 | 06:57 PM
I fry gay turkeys
Default Re: (daLixz25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daLixz25 &raquo;</TD></TR><TR><TD CLASS="quote">try starting with a compression test..</TD></TR></TABLE>
dohhh.. forgot that part.. to compression test.
Old Feb 4, 2005 | 10:34 PM
calxtreme's Avatar
good thing it still runs.
Old Feb 4, 2005 | 11:12 PM
neo1z's Avatar
Default Re: (calxtreme)
You sound like youre lucky to me. Even if it is minor valve damage - at least its not all she wrote.
Old Feb 5, 2005 | 11:41 AM
1Quikgsr's Avatar
id say the valve do a compression test
Old Feb 6, 2005 | 02:24 AM
billyhoe's Avatar
Default Re: (1Quikgsr)
it didnt hydrolock, i would say it was close to getting there tho. open ur distributor cap make sure everything in there is dry also. i ran into a puddle and literally it look'd like a wave came ontop of the car. while driving it would want almost stall out but once everything got dry its back to normal
Old Feb 6, 2005 | 07:00 AM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: (billyhoe)
Get a leak down test done by a professional and they can narrow it down to the valve, seals, etc... Then go from there.
And yeah, you didn't hydro"lock". You came close. I hydrolocked and had bent rods and 3 holes in my block. That's hydrolocking! Doh!!
Old Feb 6, 2005 | 07:21 AM
Convoy's Avatar
did u change ur oil??
Old Feb 6, 2005 | 09:18 AM
s2kkid's Avatar
Default Re: (Gee3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gee3 &raquo;</TD></TR><TR><TD CLASS="quote">Get a leak down test done by a professional and they can narrow it down to the valve, seals, etc... Then go from there.
And yeah, you didn't hydro"lock". You came close. I hydrolocked and had bent rods and 3 holes in my block. That's hydrolocking! Doh!! </TD></TR></TABLE>
How the hell did u get that much water in there LOL
Old Feb 6, 2005 | 10:20 AM
FormulaGSR's Avatar
Default Re: (vtecluder97)
normally hydrolock doesnt bend valve it bends rods. you probably bent a rod slightly, allowing it to run, but not well. a compression test will give you a indication. also try pulling your plugs put a straight edge across the volve cover and a rod down the sparkplug holes. a long screw driver will work. maje sure pistons are coming up equal distance. 1 and 4 2 and 3 are companion cylinders i think (maybe wrong) they will be at the same place on each stroke. or you can drop the pan and look at the rods from below. I bet you money that one has a slight bend in it. I did the same thing. its easy to fix. drop the pan and pull the head. pop the pistons out the top. have new rods pressed on and reassemble. sounds ghetto but i did it 40k and 200+lbs of nitrous ago.
Btw did you change your oil?
Old Feb 6, 2005 | 11:08 AM
pubestripe's Avatar
yeah didnt u know that our cars dont float? what did u get into?
Old Feb 6, 2005 | 11:30 AM
randomstrike15's Avatar
Default Re: (pubestripe)
i hydrolocked my old 87 crx prob 3 times.
i just cranked and cranked and cranked and it shot out all the extra gas and whatever else, big clouds of smoke. drove it the rest of the day. changed the plugs at home... ran stong forever...
Old Feb 6, 2005 | 03:19 PM
pubestripe's Avatar
Default Re: (randomstrike15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by randomstrike15 &raquo;</TD></TR><TR><TD CLASS="quote">i hydrolocked my old 87 crx prob 3 times.
i just cranked and cranked and cranked and it shot out all the extra gas and whatever else, big clouds of smoke. drove it the rest of the day. changed the plugs at home... ran stong forever...</TD></TR></TABLE>
lol, i guess that works too!!!
Old Feb 8, 2005 | 05:19 PM
2k1 GSR's Avatar
yea oil has been changed
Old Feb 8, 2005 | 05:37 PM
HONDA_TYPE_R's Avatar
Default Re: (FormulaGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FormulaGSR &raquo;</TD></TR><TR><TD CLASS="quote">normally hydrolock doesnt bend valve it bends rods. you probably bent a rod slightly, allowing it to run, but not well. a compression test will give you a indication. also try pulling your plugs put a straight edge across the volve cover and a rod down the sparkplug holes. a long screw driver will work. maje sure pistons are coming up equal distance. 1 and 4 2 and 3 are companion cylinders i think (maybe wrong) they will be at the same place on each stroke. or you can drop the pan and look at the rods from below. I bet you money that one has a slight bend in it. I did the same thing. its easy to fix. drop the pan and pull the head. pop the pistons out the top. have new rods pressed on and reassemble. sounds ghetto but i did it 40k and 200+lbs of nitrous ago.
Btw did you change your oil? </TD></TR></TABLE>
Ahhh...someone from my hometown...rare sight.
I would definitely do a compression test. Chances are you may have bent a rod slightly and it's causing the odd noise at low rpm's...you would think it would cause it higher up though. What kind of noise is it making? Like a rod knocking sound or a clicking sound?
Old Feb 8, 2005 | 06:50 PM
Gee3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecluder97 &raquo;</TD></TR><TR><TD CLASS="quote">
How the hell did u get that much water in there LOL</TD></TR></TABLE>
Thanks to an AEM CAI without the bypass and a flashflood at the low part of a roadway... Needless to say, my wife does not drive my car anymore after that incident.
Old Feb 10, 2005 | 04:56 PM
2k1 GSR's Avatar
Default Re: (Gee3)
sounds like the valves are tickin a lil more than normal
Jessica Rabbet
Oct 25, 2012 03:45 PM
90crxlst
10
Mar 9, 2006 10:09 AM
type Gendy
24
Nov 16, 2004 05:37 PM
DOHCon15s
Dec 3, 2003 06:11 AM
FOrSfEd
Nov 13, 2003 09:07 PM
