84.5mm headgasket on 83mm bore block ?????
I have a 83mm bored gsr block and the seller sent me an Honda oem 84.5mm headgasket. Will this be fine to use or should I sell it and buy an 83mm one. I will probably be running between 20-25 lbs of boost. Thanks
No, don't cheap out on the most important gasket of the motor; it will not work, specially with that much pressure. A 83mm HG will probably be hard to find. Good luck.
bumpin_bass
Jan 30, 2005 11:33 PM
RICE POLICE SIP
Apr 22, 2004 12:41 PM
