HELP b20 vtec blowing oil filter seal. SEARCHED
Old Jan 30, 2005 | 03:56 PM
fabs's Avatar
Default HELP b20 vtec blowing oil filter seal. SEARCHED
i have a built b20 vtec with 12.5 comp and skunk stage 2 cams. i noticed the oil filter seal popping and leaking. i tried like 4 diff filters yesterday. all blew. i tried the s2000, fram, purolator, and like 3 cheap ones from my buddies shop. all wit the same result. i used one of the plugs in the back of the block and put a fiiting wit a pcv valve to the intake manifold. still no luck .
please help
fabs
Old Jan 30, 2005 | 04:50 PM
StyleTEG's Avatar
Default Re: HELP b20 vtec blowing oil filter seal. SEARCHED (fabs)
Might be a basic question, but to be sure...
Have you checked to see if there is another oil filter gasket stuck to the block from an old filter?
Old Jan 30, 2005 | 05:53 PM
fabs's Avatar
yea. i checked. i was hoping that was the prob at first. but no luck.
thanx
fabs
Old Jan 30, 2005 | 06:52 PM
fabs's Avatar
Default Re: (fabs)
Old Jan 30, 2005 | 09:20 PM
fabs's Avatar
Default Re: (fabs)
will a catch can solve the problem, im leaning toward to much crank case pressure. so if i install a catch can for the block, then make 2 holes in the valve cover using fittings to run 2 lines to a diff catch can. should that fix my problem.
any other solutions,
fabs
Old Jan 31, 2005 | 05:43 AM
Dan GSR's Avatar
Default Re: (fabs)
doesn't make sense
have you put a guage on the engine to see what the oil pressure is doing?
are you sure you tightened the filter enough?
only other thing i can think of is the mating surface of the oil filter is warped
Old Jan 31, 2005 | 11:15 AM
FerioVtec94's Avatar
do b20s have factory oil coolers like the gsr's? if so you might want to check to see if its that seal thats leaking and not the filter
Old Jan 31, 2005 | 11:26 AM
DonF's Avatar
Default Re: (FerioVtec94)
Your relief valve in the oil pump is stuck closed. The filter is before the oil pressure sensor, so that info will not help, the seal will blow before you see the high oil pressure.
Old Jan 31, 2005 | 04:37 PM
fabs's Avatar
Default Re: (DonF)
i heard that maybe if i use lighter oil such as 5w-20 the problem may fix. how can i chech the relief valve to see if it is shut. this is driving me crazy. and is my daily driver for now.
Old Jan 31, 2005 | 06:25 PM
fabs's Avatar
Default Re: (fabs)
going crazy ................
Old Feb 1, 2005 | 06:52 AM
fabs's Avatar
Default Re: (fabs)
anybody else kno what it could be........................
Old Feb 1, 2005 | 01:12 PM
NJIN BUILDR's Avatar
Default Re: (fabs)
DonF gave you the answer.The stock pump on cold oil with the relief valve stuck closed can make well over a hundred pounds as soon as you hit the throttle.
Glenn
Old Feb 1, 2005 | 04:30 PM
fabs's Avatar
Default Re: (NJIN BUILDR)
yes DonF has given me good advice . tommorrow morning i wil check the relief valve. hopefully this will fix my issue.
thanx for eveyones help,
fabs
Old Feb 2, 2005 | 02:03 PM
fabs's Avatar
Default Re: (fabs)
i pulled the oil pan off and checked the valve seemed to be fine. i put the pan back on put a fram filter(3593a) and turned the car on, i let it sit and then the leak still didnt stop. the oil presure did go down to 80 instead of 95. what else can cause this.
Old Feb 2, 2005 | 02:21 PM
msmotorsports's Avatar
Default Re: (fabs)
Something may be stuck in the oil passages which is creating the high pressure. Since the oil filter gasket is the "weakest" exit it will blow through first and leak. If something is stuck in the paasages its going to be quite hard to figure out where. Good luck.
Old Feb 2, 2005 | 03:37 PM
fabs's Avatar
Default Re: (msmotorsports)
i am gonna try the catch can to see if it will help. if that fails then i will drop the motor and rip it apart to see what is goin on. that will suck cause this motor only has 1000 miles.
Sleepy216
Nov 18, 2018 02:43 AM
DaBEast
May 16, 2012 01:08 PM
bibong
Aug 20, 2007 07:54 PM
asubennett
Apr 13, 2006 04:06 PM
DoyouVtec
Mar 23, 2005 08:20 AM
