NEXT HID retrofit member coming soon......Any last minute advice before the madness begins ?
Old Jan 30, 2005 | 01:42 PM
MikeTV
Guest
Posts: n/a
Default NEXT HID retrofit member coming soon......Any last minute advice before the madness begins ?
Well i just bought Denso thin ballasts, ignitors and all supporting hardware from an IS300, along with 2 Audi A6 projectors with bulb connectors..i will be reviewing skafia's instructions very carefully before i even begin.........For those who have already done this mod....Is there any last minute advice or any potential problems that I should watch out for or be aware of before doing the retrofit ?? Thanks guys
Modified by Eclipse spanker at 11:48 PM 1/30/2005
Old Jan 30, 2005 | 02:37 PM
m R g S r's Avatar
Default Re: NEXT HID retrofit member coming soon......Any last minute advice before the madness begins ? (Ec
Take your time? Re-seal the headlights very well, to avoid the moisture inside the headlights. . .
Old Jan 30, 2005 | 02:45 PM
calxtreme's Avatar
measure, remeasure, then remeasure again before cutting. Take your time, don't burn your housing.
Old Jan 30, 2005 | 03:23 PM
rufridn's Avatar
good luck! post pics when done
Old Jan 30, 2005 | 03:38 PM
Cjsls's Avatar
Default Re: (rufridn)
as said already just take your time and im sure it'll come out looking great.
Old Jan 30, 2005 | 05:18 PM
95TEG's Avatar
Default Re: (Cjsls)
Where did you score all the goods from?
Old Jan 30, 2005 | 06:40 PM
MikeTV
Guest
Posts: n/a
Default Re: (95TEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95TEG &raquo;</TD></TR><TR><TD CLASS="quote">Where did you score all the goods from?</TD></TR></TABLE>
I got the HID kit from someone here on H-T, and I got the projectors from ebay.
IS300 HID setup including Denso thin ballasts, d2r bulbs and ignitors: $250 shipped
Audi A6 projectors with bulb connectors: $150 shipped
$400 altogether......not the best deal, but not the worst deal either
I wanna thanks Patrick GSR, and the rest of you guys that helped me go from being totally HID ignorant, to piecing together my first setup ..thanks a million guys
p.s. I noticed that on Skafia's HID website, in his other directory labeled itr, he is standing in front of a stolen itr.....was that the same car that he did the HID retro on......if so, that sucks so bad....
Old Jan 31, 2005 | 05:18 AM
MikeTV
Guest
Posts: n/a
Default Re: (Eclipse spanker)
i just found out that it was his car........
Old Feb 1, 2005 | 08:08 PM
fastrunner's Avatar
If you follow Skafia's instructions with wiring you are gonna have a problem, make a harness and use a relay to do it right and not start a electrical fire. check out HID planet if you havent already search for harness, it'll show you the better way to do it
anoble1
Lighting
Dec 24, 2017 05:44 PM
theeogflip
14
Mar 16, 2008 08:56 PM
EJ8 GSR-T
Jan 28, 2007 12:07 PM
ChaseIntegra
Jan 19, 2005 05:19 AM
PatrickGSR94
Oct 25, 2004 07:36 PM
