power wire in a DA
Old Jan 30, 2005 | 11:55 AM
DarkDragon's Avatar
Default power wire in a DA
like the title shows i need a place to run my power wire from battery to hatch but cant seem to find a place. Its a 90 LS and i need to run 4G wire. I found 1 hole that was near the steering colum coming out of the firewall but when i shine light thru it shines around a pedal and the openeing is to small. Pleas help
Old Jan 30, 2005 | 04:06 PM
juachoutnow's Avatar
Default Re: power wire in a DA (DarkDragon)
i know this sounds ghetto but when i had my DA, i ran the power wire through the passenger side fender... it worked for me, cause i couldnt find a hole in the firewall either...
Old Jan 30, 2005 | 04:36 PM
DarkDragon's Avatar
Default Re: power wire in a DA (juachoutnow)
ok ill keep that in mind since ur the only other person to reply and we both couldnt find a hole in the firewall
Old Jan 30, 2005 | 05:38 PM
Nicknyce's Avatar
i couldnt find a hole either...
Old Jan 31, 2005 | 09:09 AM
fcm's Avatar
fcm
Old Fart
Default Re: (Nicknyce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkDragon &raquo;</TD></TR><TR><TD CLASS="quote">like the title shows i need a place to run my power wire from battery to hatch but cant seem to find a place. Its a 90 LS and i need to run 4G wire. I found 1 hole that was near the steering colum coming out of the firewall but when i shine light thru it shines around a pedal and the openeing is to small. Pleas help</TD></TR></TABLE> There should be some unused grommets on the pass. side of car half way down firewall, you may have to remove a few things to access them. 94
fryman
Aug 30, 2009 07:48 PM
rollercosta123
Aug 16, 2006 12:30 PM
SpoonyDC5
Dec 13, 2005 12:47 PM
cd5_2NR
Audio / Security / Video
Apr 20, 2003 09:47 PM
