light ticking sound in valvetrain please help???
Old Jan 30, 2005 | 10:53 AM
cxVtecC1's Avatar
Default light ticking sound in valvetrain please help???
i recently put together an Ls motor to swap into my teg,car seems to be running fine but it has a little tick, i thought that i needed a valve adjustment so i had that done, What else could be making the valverain tick,and if its not the valvetrain could it be a small sign of detination?, if so what could i do to help with my issue,Could i have some kind of a timing issue??????????
Old Jan 30, 2005 | 05:42 PM
BeavisB16's Avatar
Default Re: light ticking sound in valvetrain please help??? (cxVtecC1)
If you are running an aftremarket header, the material used is thinner than stock so you can hear the valves ticking. If you have done a valve adjustment, they are probably ok.
Old Jan 31, 2005 | 10:43 AM
cxVtecC1's Avatar
Default Re: light ticking sound in valvetrain please help??? (BeavisB16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BeavisB16 &raquo;</TD></TR><TR><TD CLASS="quote">If you are running an aftremarket header, the material used is thinner than stock so you can hear the valves ticking. If you have done a valve adjustment, they are probably ok.</TD></TR></TABLE>
Thanks beavis, I do run an aftermarket header so that could be what is causing it, but ive heard that this type of sound could be caused by some small amount of detination, im wondering if ignition timing could be off a hair, i did mark the distributor when i started the rebuild but it could be off a little, i need a timing light.Could this affect anything with these symptoms?
Old Jan 31, 2005 | 01:50 PM
Brett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxVtecC1 &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks beavis, I do run an aftermarket header so that could be what is causing it, but ive heard that this type of sound could be caused by some small amount of detination, im wondering if ignition timing could be off a hair, i did mark the distributor when i started the rebuild but it could be off a little, i need a timing light.Could this affect anything with these symptoms?</TD></TR></TABLE>
yes. get a timing light and make sure your timing is correct. knocking and pinging sounds like bb's in a can.
Old Jan 31, 2005 | 01:57 PM
Combustion Contraption's Avatar
it also sounds like a boat anchor dropping..
Don JD
Sep 30, 2009 10:03 AM
c-way
Aug 30, 2004 08:03 AM
King_j
May 16, 2004 07:04 PM
DC 2
Apr 8, 2004 09:23 PM
SleepnCiViC
Feb 13, 2004 08:43 PM
