how can you tell if vtec is working?
Old Jan 14, 2002 | 01:39 PM
garagespecial
Guest
Posts: n/a
Default how can you tell if vtec is working?
my b16a seems like my vtec isnt working now?....when i first got my swap it was hella loud but now it sounds like a lil bizznitch
Old Jan 14, 2002 | 01:57 PM
Mario's Avatar
Default Re: how can you tell if vtec is working? (garagespecial)
Let me drive that thing, and i'll tell you if it's working or not.
Old Jan 14, 2002 | 02:42 PM
navin's Avatar
i think you should get a "Check Engine" light if VTEC is not functioning properly, thats what I think. any other opinions
Old Jan 14, 2002 | 02:47 PM
senpai's Avatar
Default .......
You could always hook up a led to your VTEC solenoid and see if it lights up. Also, can't you just tell if it's working?
Old Jan 14, 2002 | 03:10 PM
garagespecial
Guest
Posts: n/a
Default Re: ....... (maztur)
my engine check light doesnt ever come on why i dont know
Old Jan 14, 2002 | 03:39 PM
OR-G's Avatar
Default Re: ....... (garagespecial)
I'm not too technical, but on my vtec(that which I have on the VX) I can usually hear a whine when I hit 4000rpm.
Old Jan 14, 2002 | 04:10 PM
garagespecial
Guest
Posts: n/a
Default Re: ....... (OR-G)
thanks for all the replies.....Mario....photoshoot friday? hit me up garagespecial@aol.com
Old Jan 15, 2002 | 06:13 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
hook a oil pressure guage up to the fitting on the head, next to the vtec solenoid, then drive the car. if it jump from 0psi to 75 psi or so, you know the everything up to and including the vtec solenoid is good. if there is a mechanical problem after the solenoid, you need to put 70 psi of air pressure to the aforemention fitting in the head and check vtec manually. it's all in the manual (helms) folks.
PWRDbyHseries
Apr 7, 2008 07:46 PM
si90rex
Jul 5, 2006 03:12 PM
J's GS-R
Feb 23, 2006 06:14 PM
fso_BamBam
Jun 26, 2001 04:13 AM
