fuel relay????
Old Jan 30, 2005 | 10:28 AM
onekoop's Avatar
Default fuel relay????
i have a 91 crx with a 96 ls motor. Recently my car doesnt start and i checked the injectors and theres no fuel comming out. The fuel pump works and it gets the fuel to the fuel rail but not thru the injectors. Something is keeping it from comming out. I thought at first they were clogged but its not likely for all four to stop working at the same time. Im thinking my fuel relay as gone bad??? Wheres is the fuel relay located?? Could it be my resistor box?? It has to do with wiring of some sort. If anybody has had this problem can u help me.
thanx
Old Jan 30, 2005 | 12:36 PM
crxtreme89h's Avatar
Default Re: fuel relay???? (JDMpnOi)
Does your fuel pump prime when you turn the key on? Can you hear it? If it is your relay you won't be able to hear the fuel pump prime up. The relay is under the drivers side kick panel.
civic28
Mar 26, 2014 04:18 PM
Jruiz3505
Dec 6, 2011 02:40 PM
EGKREW
Nov 26, 2008 11:54 AM
willpoorman
Oct 17, 2008 04:09 PM
bigbacon2
Jul 31, 2005 05:34 PM
