Idle with 370cc injectors?
Did a search on this and couldn't find a definitive answer.
If I run 370cc injectors without an electronic fuel controller like a VAFC, will I see problems with my idle? Will simply lowering my idle fuel pressure solve this problem?
Thanks.
Thanks.
If I were you I would go 310's with the charger. If you already got 370's e-mail me privately and I will give you some base settings to make your car idle like stock.
EVIL
EVIL
I guess I'll start looking for a set of 310s. Thanks.
Was only looking into the 370s because I saw a set of them being sold for $200.
Man.. i wish injectors, FMUs, and fuel pumps were cheaper... hahahha.
We are running 370cc injectors on my buddy's B18C1 powered Civic. It will idle once you get the car started.
The only problems we have run into without using an AFC are:
1. Start up: The car doesn't want to start until you try it a couple of times
2. Throttle: We get slight hesitation in the lower RPM's when we hit full throttle. This goes away once we begin to spool.
The car is an 11 second daily driven vehicle, so it drives fine other than these two minor issues. You can see the car's setup at http://www.b18bomber.freeservers.com/b18bomber.html
Good Luck!
Good Luck!
vtecmissle
Feb 19, 2006 11:47 PM
racinskittle
Jan 18, 2004 07:06 PM
