OBD-1 b16 into CRX
Old Jan 30, 2005 | 08:46 AM
BeavisB16's Avatar
Default OBD-1 b16 into CRX
I have the b16 swap from my damaged 93 coupe. I know the engine is in good shape, and the tranny and basically know what im getting. I know I will have to run the hydro to cable converter. But as far as wiring what will I need. Everything is OBD-1 and I would like it to stay that way. I want to run hondata. I have the coupe at my disposal, basically I can strip it. What would I have to do with the shift linkage, if anything? Any help would be much appreciated.
Old Jan 30, 2005 | 08:56 AM
eda6's Avatar
Default Re: OBD-1 b16 into CRX (BeavisB16)
from the 93 use the 4 wire o2 sensor, ecu, dizzy. Get a conversion harness from blown90hatch.
Not sure if you can use your 93 shift linkage. I found a DA linkage and shortened it.
If your crx is dpfi, you'll need to convert to mpfi.
Old Jan 30, 2005 | 08:59 AM
BeavisB16's Avatar
Default Re: OBD-1 b16 into CRX (eda6)
My CRX is MPFI. SO just a conversion harness and shift linkage and I will be set? And of course the mounts and converter (hydro-cable)
Old Jan 30, 2005 | 09:04 AM
eda6's Avatar
yea...i'd also get a new timing belt/water pump and change as many gaskets as possible before you drop the motor in. vtec and knock sensor wiring must be added.
Modified by eda6 at 10:26 AM 1/30/2005
Old Jan 30, 2005 | 09:36 AM
BeavisB16's Avatar
cool, i was hoping it wouldn't be some huge deal.
Old Jan 30, 2005 | 04:54 PM
BeavisB16's Avatar
What axles do I need? I have heard integra axles will work but others disagree.
Old Jan 30, 2005 | 05:12 PM
doublethink's Avatar
90-91 Integra (NON ABS)
Old Jan 30, 2005 | 05:17 PM
TIRENECK's Avatar
Default Re: OBD-1 b16 into CRX (doublethink)
u need to use the obd0 engine harness for the b16, wiring the obd1 engine harness gonna be a bitch.
Old Jan 30, 2005 | 05:27 PM
BeavisB16's Avatar
Default Re: OBD-1 b16 into CRX (TIRENECK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TIRENECK &raquo;</TD></TR><TR><TD CLASS="quote">u need to use the obd0 engine harness for the b16, wiring the obd1 engine harness gonna be a bitch.</TD></TR></TABLE>
Why would you say that? The engine is already OBD-1. Don't I just need the conversion harness?
Old Jan 30, 2005 | 07:07 PM
BeavisB16's Avatar
also with the axles, do I need to alter anything on my HF in order to run the integra axles.
Old Jan 30, 2005 | 07:14 PM
PHOBIA's Avatar
no all you need is the conversion harness,its plug and play,it comes with instructions and all.hey for any reason you chane your mind you can always sell me your distributer that about it.it sems like you have every thing coverd,and you can use 90-93 integra axles there the same thing and all have th same part #.
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BeavisB16 &raquo;</TD></TR><TR><TD CLASS="quote">Why would you say that? The engine is already OBD-1. Don't I just need the conversion harness?</TD></TR></TABLE>
I think he meant wiring up your 93 engine harness to plug into your CRX. He's saying just use the engine harness out of your CRX and modify it to plug into your B16.
If you dont know how to do wiring ask nikitad, Blown90Hatch, or droppedcrxsi for a custom engine harness that is plug and play and also ask them for a OBD 0 to OBD 1 conversion harness. If you decide to buy that stuff instead of wiring it up yourself, make sure you get both of them from the same person.
EDIT: Forogot to mention that I had to do all that above stuff because I had a DX. I dont know what kind of changes you Si or HF guys have to do to the engine harness. So maybe you just need to swap a few wires around, I dunno. I'll let the guys with HF's and Si's answer that for you.
Old Jan 30, 2005 | 08:42 PM
PHOBIA's Avatar
nothing need to be changeg when using a si or hf,the only thing you need to do is run the wires for vtec engagement just like you would do with any other car not allready equiped
bradennicely
Jan 25, 2009 03:14 PM
folta2169
18
Dec 14, 2004 06:35 PM
b18bcrx
Dec 1, 2004 04:12 PM
crx1856
May 30, 2003 03:29 AM
si foo
17
Mar 4, 2002 03:01 PM
