auto to manual swap (what do i need?)
Old Jan 30, 2005 | 12:03 AM
95slowmattic's Avatar
Default auto to manual swap (what do i need?)
i have a 95 civic that im making a manual. i heard that it's actually not that hard. what exact parts do i need? could i get it done in a weekend? could i use a pedal set from a different car rather than a civic or am i stuck with the civic set? thank you for your help.
Old Jan 30, 2005 | 02:35 AM
RICE POLICE SIP's Avatar
Default Re: auto to manual swap (95slowmattic)
i'll help you out since the search function isn't working... but i'm gonna go eat... it's really easy, I did it myself....
Old Jan 30, 2005 | 02:58 AM
130R's Avatar
im guessing ur car is an eg? you would need a welder/cutter. ek's are alot easier to do.
Old Jan 30, 2005 | 05:18 AM
wishingiam's Avatar
Default Re: auto to manual swap (carbing'ed)
pedals (integra 94-00 will work or 92-00 civic) clutch line,master, and slave, for eg hasport trans mount (auto to 5spd) trans,shift linkage,clutch ,and flywheel and i think you'll also need axles not too sure though and most important ecu. yes
you should be able to do it yourself in one weekend as long as you have basic mechanical knowledge and tools. and one more thing search next time I'm new here too and the search has been working fine for me
Old Jan 30, 2005 | 05:25 AM
TeamNextGenChris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carbing’ed &raquo;</TD></TR><TR><TD CLASS="quote">im guessing ur car is an eg? you would need a welder/cutter. ek's are alot easier to do.</TD></TR></TABLE>
why do you need a welder/cutter?do you mean the mount issue?if so,there a revarious companies making mounts now.
chris
Old Jan 30, 2005 | 10:44 AM
Default Re: auto to manual swap (phuckyou)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phuckyou &raquo;</TD></TR><TR><TD CLASS="quote">pedals (integra 94-00 will work or 92-00 civic) clutch line,master, and slave, for eg hasport trans mount (auto to 5spd) trans,shift linkage,clutch ,and flywheel and i think you'll also need axles not too sure though and most important ecu. yes
you should be able to do it yourself in one weekend as long as you have basic mechanical knowledge and tools. and one more thing search next time I'm new here too and the search has been working fine for me </TD></TR></TABLE> You can use the same axles... You'll also have to jump two big wires that go to the "shifter" otherwise the car won't start cause' it thinks it's NOT in park.... Let me know if you have any other questions..
alexdaboss291
Nov 13, 2007 07:35 PM
IMPORT_IMAGE
Oct 23, 2007 12:31 PM
dafuzzbudd
Feb 28, 2007 08:27 PM
B-SerioUs EGg
Jul 18, 2005 01:36 PM
NinetyTwoHB
Feb 21, 2004 12:41 PM
