exedy clutch on ebay
goin for around $100 for 99-00 si and vendors on here sell for around $220. im guessin somethin aint right about the ebay ones, are they reconditioned, poorer quality parts etc ?
http://cgi.ebay.com/ebaymotors...33730
I've purchased several of these clutches for d-series motors. These are not performance units, they are the same as stock. They do a damn fine job though.
feedback is good and its says original so must be oem replacement. i need slightly better then oem so need the organic or may just go for oem itr
thanks for help guys, saved me makin mistake
edit : i will only be pushin a maximum 50 flywheel bhp over stock ( NOT whp) and 30 ft lbs torque on my b16. will oem be fine ?
i bought my exedy stage I and lightweight flywheel combo off ebay, good price and like everyone else said just make sure the person/company selling has some good feedback and you should be fine. Mods are in my sig but i would go with the stage I like i did, feels pretty close to stock but is a small upgrade and has been great so far!!
THIS IS NOT THE SAME KIT HT SPONSORS SELL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
THEY do not list a part number on ebay because they are NOT the 8803's (ithink that is the part number) that sponsors sell...exedy organic....
this clutch is junk!!!!
ask them for a part number!! they won't give it to you cause it is a stock replacement clutch....NOT THE ORGANIC!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">THIS IS NOT THE SAME KIT HT SPONSORS SELL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ask them for a part number!! they won't give it to you cause it is a stock replacement clutch....NOT THE ORGANIC!!!</TD></TR></TABLE>
Yup, thas what i thought.
thanks for replies and concluded it is just oem replacement.
gonna just get myself either the organic of vendor on here or oem itr dependin which i can get cheaper
can someone confirm this is correct part no for the exedy organic for 99-00 si -
E4208800B ?
Modified by vti444 at 9:54 AM 2/2/2005
E4208800B ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sidesi »</TD></TR><TR><TD CLASS="quote">if you will be adding more power...
save up a little more for an ACT HDSS with lightened flywheel.
you will be glad you did.. they can take a beating </TD></TR></TABLE>
oh soooo wrong.....running the EXEDY organic 8800 on my 220 whp car....with lighten flywheel (i agree on the flywheel)
you don't need a massive clutch...it just adds wear and tear on your drive train
well allow me to retort....
not really wrong.. but can be corrected
the clutch won't add wear and tear.. more horsepower and the way the car is driven will.
sounds like you have the exedy stage one organic (which is rated 42% over stock), what was originally posted is same as stock
I bought an exedy clutch (the stage 1 organic) and a lightweight flywheel from ebay for my 00 and have not had a single problem with it. Like it was mentioned before, just make sure you look at the feedback.
pliskin679
Aug 20, 2010 09:46 PM
99sonicbluegsr
25
Mar 26, 2005 10:04 AM
