Using JB Weld to fix a Crankshaft?
Old Jan 29, 2005 | 11:14 PM
I Want An Si's Avatar
Default Using JB Weld to fix a Crankshaft?
Similar to that damage.... (maybe a little longer)
JB Weld claims it can hold up to 500 Degrees... and its as hard as steel once dried... Any Ideas..input etc...
Old Jan 29, 2005 | 11:26 PM
91civicEX's Avatar
Default Re: Using JB Weld to fix a Crankshaft? (I Want An Si)
ur trying to use jb weld instead of the little key peice? everyone will tell you not to do it but whats the harm in trying? your alternator will stop working
Old Jan 29, 2005 | 11:33 PM
Rspec CX's Avatar
Default Re: Using JB Weld to fix a Crankshaft? (91civicLX)
I think he is going to use the jb weld to fix the chunk missing where the key goes, man I know those things fit in there tight so most likely you still have enough of the area to hold the key in place but if you want just a little bit of added strength go for it, it couldnt hurt.
Old Jan 29, 2005 | 11:39 PM
civicdust's Avatar
Default Re: Using JB Weld to fix a Crankshaft? (Rspec CX)
go get it for free at pick a part
Old Jan 29, 2005 | 11:40 PM
RCautoworks's Avatar
Jb weld could crack, yes it would be good for added saftey but if your really looking for something that will hold. Check this stuff out
http://www.coolchem.com
Its a space age glue that needs a special chemical to react to foam the hold. I would buy this stuff, then use jb weld to be on the safe side.
Old Jan 29, 2005 | 11:59 PM
shocker's Avatar
what the crazy space age ish
Old Jan 30, 2005 | 12:05 AM
Default Re: (shocker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shocker &raquo;</TD></TR><TR><TD CLASS="quote">what the crazy space age ish</TD></TR></TABLE>
aww what . That glue should really be advertised more but I think the company is so little it can't afford it.
I have seen the stuff in action, the guy glued an alternator belt back together and no one could rip it apart.
He was gluing aluminum to wood, wood to rubber, plastic to wood and so on.
Old Jan 30, 2005 | 12:21 AM
Default Re: Using JB Weld to fix a Crankshaft? (2186)
get the crankshaft for free at pick a part?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2186 &raquo;</TD></TR><TR><TD CLASS="quote">go get it for free at pick a part</TD></TR></TABLE>
Old Jan 30, 2005 | 08:02 AM
hahagasdcrx's Avatar
And they say JB weld will fix anything.
Actually take it to your local welder, and see if they can fill in the chip with a good weld.
Anyone good at welding can make it perfect and still fit the woodruff key snuggly.
Old Jan 30, 2005 | 08:03 AM
HatchBox's Avatar
Skoobie no more...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Want An Si &raquo;</TD></TR><TR><TD CLASS="quote">get the crankshaft for free at pick a part?</TD></TR></TABLE>
seriously, what could it cost 5 bucks?
then you dont have to worry about it.
Old Jan 30, 2005 | 09:06 AM
Nic's Avatar
Nic
i dont get what I am looking at...the little chunk of metal that slipis inthere? If that is what you are talking about then go buy one JB WELD WILL NOT WORK
Old Jan 30, 2005 | 09:11 AM
Rspec CX's Avatar
Default Re: (stk hatch)
He is not looking for the woodruf key, can you all not see the chunk of metal missing from the crank shaft end where the keys goes? Everyone keeps saying to get one at the junkyard but it is obvious that he is not talking about the key.
Old Jan 30, 2005 | 09:15 AM
Default Re: (Rspec CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rspec CX &raquo;</TD></TR><TR><TD CLASS="quote">He is not looking for the woodruf key, can you all not see the chunk of metal missing from the crank shaft end where the keys goes? Everyone keeps saying to get one at the junkyard but it is obvious that he is not talking about the key.</TD></TR></TABLE>
Finally someone with more than an ounce of intelligence
Old Jan 30, 2005 | 09:17 AM
Beetle's Avatar
try the JB Weld but make sure it is clean and then fit the keyway if it doesnt work you arent out anything more than you are right now
Old Jan 30, 2005 | 09:18 AM
Default Re: Using JB Weld to fix a Crankshaft? (HatchBox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox &raquo;</TD></TR><TR><TD CLASS="quote">
then you dont have to worry about it. </TD></TR></TABLE>
A CRANKSHAFT!!!!!!!!! NOT A CRANK PULLEY NOT A WOODRUFF KEY!!!!!!!!!!!
A CRANKSHAFT!!!!!!!!!!!!!!!!!!!!!!!!
Old Jan 30, 2005 | 09:19 AM
HatchBox's Avatar
Skoobie no more...
seee what happens when one fails to read after he has awaken
Old Jan 30, 2005 | 09:30 AM
akb16's Avatar
seen somebody do it with "jb" already and it worked out well
Old Jan 30, 2005 | 09:56 AM
Default Re: (I Want An Si)
Finally someone with more than an ounce of intelligence</TD></TR></TABLE>
Look at my reply, I already have you a solution that is sure to work.
eg-spoon
Paint and Body
Dec 3, 2009 01:13 PM
arc_55
Welding / Fabrication
24
Apr 8, 2007 06:46 PM
Keyhole
Sep 13, 2005 08:53 AM
JMFabrications
Feb 2, 2005 04:07 PM
integra6650
Jun 30, 2004 09:46 PM
