Using JB Weld for crankshaft repair?
Old Jan 29, 2005 | 10:12 PM
I Want An Si's Avatar
Default Using JB Weld for crankshaft repair?
Similar to that damage.... (maybe a little longer)
JB Weld claims it can hold up to 500 Degrees... and its as hard as steel once dried... Any Ideas..input etc...
Old Jan 29, 2005 | 10:37 PM
oneslowls's Avatar
Default Re: Using JB Weld for crankshaft repair? (I Want An Si)
Actually, every now and then we get this kind of thing at the subaru dealer I work for. The key way gets stuck on the crank pulley and shears off like what you posted on the picture. We use JB weld to fix this problem, works excellent. Just mix it properly and shape it so the key way fits properly and your set. Like I said been doing this type of repair for years and never had a problem, you should be fine.
Old Jan 29, 2005 | 11:34 PM
ExploitedRacing-HR's Avatar
JB weld is really that strong? The only thing i guess i would be worried about is the JB weld not adhearing to the workpeice properly.
Old Jan 29, 2005 | 11:42 PM
RCautoworks's Avatar
Default Re: (ExploitedRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExploitedRacing &raquo;</TD></TR><TR><TD CLASS="quote">JB weld is really that strong? The only thing i guess i would be worried about is the JB weld not adhearing to the workpeice properly.
I would worry about it cracking off after a certain amount of time. This product
http://www.coolchem.com and jb weld will get the job done.
Old Jan 30, 2005 | 11:34 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: (90blackcrx)
i break jb weld, it doesnt work for ****, imo. it cracked in half, dont half *** it, go get someone to weld it for you
Old Jan 30, 2005 | 12:25 PM
HybridHatchC1's Avatar
Default Re: (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">i break jb weld, it doesnt work for ****, imo. it cracked in half, dont half *** it, go get someone to weld it for you</TD></TR></TABLE>
if you can crack it easily then you definitly didn't mix it right...
Old Jan 30, 2005 | 12:31 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (HybridHatchC1)
i didnt mix it, had someone else do it. trust me, the **** is easy to break. its a halfass approach to fixing something properly
Old Jan 30, 2005 | 12:56 PM
Formula Racing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">i didnt mix it, had someone else do it. trust me, the **** is easy to break. its a halfass approach to fixing something properly</TD></TR></TABLE>
Um.. They use it in Rotary engines.. Which is Serious Heat higher than that of a piston engine and it lasts years.. The fault lies in you /someone else..
Old Jan 30, 2005 | 01:31 PM
EKhatch's Avatar
Default Re: (Formula Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Formula Racing &raquo;</TD></TR><TR><TD CLASS="quote">
Um.. They use it in Rotary engines.. Which is Serious Heat higher than that of a piston engine and it lasts years.. The fault lies in you /someone else.. </TD></TR></TABLE>
If you are going to argue with the guy you may want to talk about the same type of stress factor. I don't see anywhere in his original post that said anything about the product failing under high temperature.
Old Jan 30, 2005 | 03:03 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (EKhatch)
yea, it didnt fail because of heat, it failed because of torsional stress, pushing/pulling etc
just my .02, but i wouldnt even use jb weld to fix my lawnmower
Old Jan 30, 2005 | 05:03 PM
Want2race's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKhatch &raquo;</TD></TR><TR><TD CLASS="quote">
If you are going to argue with the guy you may want to talk about the same type of stress factor. I don't see anywhere in his original post that said anything about the product failing under high temperature. </TD></TR></TABLE>
while your point is valid I have other experience that shows that torsional stresses can be as great. I have seen the army use it on certain jet repairs in operation times as well! Thats a statement of its ability!
As for the other guy.. He has shown a pretty strong dislike for the product and I am inclined to believe that it is ignorantly so.
Old Jan 30, 2005 | 05:17 PM
BEEYOND's Avatar
Default Re: (Want2race)
how the heck is JB weld going to weld itself onto the crankshaft... I gaurantee anyone that after JB weld cures I can use a 12mm wrench from Walmart and knock the JB weld into pieces... IF not at least I could knock it off the crank where it supposedly adhered to.... POS JB weld failed numerous times..haha!!\
all IMO so no offense.... and through my experience...
Old Jan 30, 2005 | 07:42 PM
alleyezonme's Avatar
Default Re: (lsvtecpower)
my vss broke on my motor and i tried to just fix it with jb weld. and it broke to ****. i used an epoxy and that held together better. maybe it was my mixing that f'd it up, but if i were you i would keep my eyes peeled for a better solution.
Old Jan 30, 2005 | 08:17 PM
2KWK4U's Avatar
I do not have any exp. using JB Weld, but I personally would fix it the right way, and have it welded, or weld it myself.
Old Jan 31, 2005 | 06:01 AM
philipwight's Avatar
Default Re: (2KWK4U)
make your own key way 180 degrees out. then mark it on the pulley 180 out
Old Jan 31, 2005 | 06:38 AM
slowdx's Avatar
to me the problem with jb weld isnt the actual jb weld breaking, but it not sticking to the part good enough, it usally falls off after a while for me.
Old Jan 31, 2005 | 09:04 AM
oneslowls's Avatar
So how is everyone mixing the JB weld? Like I said before, the techs including myself at the shop I work at all use JB weld to do crank repairs at the key way. Not once, and I mean not once have we had a problem with the JB weld not holding properly. I'm just stating from my experiences, not saying that others experiences did not happen. My personal opinion is JB weld is quick and fast, just need to mix it properly.
Old Jan 31, 2005 | 02:45 PM
zer0bot's Avatar
Default Re: (oneslowls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneslowls &raquo;</TD></TR><TR><TD CLASS="quote">So how is everyone mixing the JB weld? Like I said before, the techs including myself at the shop I work at all use JB weld to do crank repairs at the key way. Not once, and I mean not once have we had a problem with the JB weld not holding properly. I'm just stating from my experiences, not saying that others experiences did not happen. My personal opinion is JB weld is quick and fast, just need to mix it properly.</TD></TR></TABLE>
50/50 mix
zer0
Old Jan 31, 2005 | 03:26 PM
Jasper_db1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">This product
http://www.coolchem.com and jb weld will get the job done.</TD></TR></TABLE>
Coolchem is the ****
I got their test kit to try it out and it worked as advertized.
Old Jan 31, 2005 | 03:28 PM
Default Re: (Jasper_db1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jasper_db1 &raquo;</TD></TR><TR><TD CLASS="quote">
I got their test kit to try it out and it worked as advertized.</TD></TR></TABLE>
, if more people would buy it and spread the word. I believe this product would be on everyones shelf.
Old Feb 1, 2005 | 12:44 PM
junkyard racer's Avatar
is this a "will jb weld work?"
its holding my block together fine.
Old Feb 4, 2005 | 03:42 PM
Default Just an Update...
its been a few days and a whole tank of gas.... JB Weld on the Crank and BLUE Loctite on the crank pulley bolt... it hasnt moved an inch so far
Old Feb 3, 2021 | 10:02 AM
T Rabenold's Avatar
I have used jbweld for many applications I would have said would never work. It not only worked but in every case never failed. One was crankshaft and another bottom hole in oil pan. I drained oil from vehicle - cleaned area with carb/brake cleaner after oil drained completely, patched with jbweld, and the pan never leaked. This is with oil exposure and heat on and off for years. Other applications filled key ways - let fully cure (this very important) and with proper assembly and centering gear/pulley to eliminate any non-normal vibration and it never broke not even budged.
I do admit every time I would look at the vehicle later I was always amazed it still worked.
ben98gs
Honda Civic (2001 - 2005)
21
Jul 9, 2007 08:30 AM
EdBoon
12
Aug 17, 2005 02:46 PM
AZNracerx1989
Welding / Fabrication
May 31, 2005 10:34 PM
Surewin
Feb 1, 2005 08:35 PM
xci_ed6
11
Jul 27, 2003 07:24 AM
