Power Steering??
OK...I am new to this forum so don't flame please...I have a question about a noise I keep hearing. Everytime I cut the wheel enough to do a uturn or even back out of the drive way..The entire pulley for the power steering begins to "rub" and create an intolorable noise. I removed the belt to see if the pulley would move but it didn't just wanted to know if it was def the power steering pump or maybe the aftermarket pulleys???? is it really worth it to replace? or just remove??
TIA
chris--
TIA
chris--
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 121cRRRd »</TD></TR><TR><TD CLASS="quote">OK...I am new to this forum so don't flame please...I have a question about a noise I keep hearing. Everytime I cut the wheel enough to do a uturn or even back out of the drive way..The entire pulley for the power steering begins to "rub" and create an intolorable noise. I removed the belt to see if the pulley would move but it didn't just wanted to know if it was def the power steering pump or maybe the aftermarket pulleys???? is it really worth it to replace? or just remove??
TIA
chris--
I don't think it would be the pump. But a lot of people have problems with the aftermarket pulleys. They dont offer much and cost way to much money. Soo my first guess would be check them out.
Good luck, sorry I cant of more help.
TIA
chris--
</TD></TR></TABLE>I don't think it would be the pump. But a lot of people have problems with the aftermarket pulleys. They dont offer much and cost way to much money. Soo my first guess would be check them out.
They're unorthodox..I have the oem's but I'm not sure about the condition kind of worn/rusted..I was going to try some noxon on them...but really not sure how good that'd be to use any suggs?
TIA
TIA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 121cRRRd »</TD></TR><TR><TD CLASS="quote"> but I'm not sure about the condition kind of worn/rusted.</TD></TR></TABLE>
it is fine.
it is fine.
Actually ....what you are hearing is the belt slipping. Notice you only hear it at full extension where resistence is most.
you can either: One - tighten the ps belt by adjusting the pump.
or two - replace the belts.
The pulleys are fine and the belts just recently started that sound while being garaged for so long.
Just my 2 cents.
Just my 2 cents.
xkrazyxjbrkerx75
38
Jul 15, 2015 07:55 PM
Powered by Rowena Galam
Feb 23, 2003 09:50 PM
