Brake Rotors/Pads issue
Old Jan 14, 2002 | 12:15 PM
BlackAxis's Avatar
Default Brake Rotors/Pads issue
I just installed new rotors and EBC greenstuff pads and I have a few questions. This is my first time doing this so I have that "I fucked up feeling"
a) How long should it take to break in with both new pads and rotors?
b) I have a slight squeeling problem, I used blue goo between the pad and the shim but it still does it, it this normal for this particular pad?
Thanks! I would post a pic of my install but it is 278 kb!
Old Jan 14, 2002 | 03:59 PM
4wsB21a's Avatar
New User
Default Re: Brake Rotors/Pads issue (BlackAxis)
when you installed the new rotors, did you have an oily, greasy film on them? if you did, i hope you cleaned it off with some brake cleaner or carb cleaner. if you didn't then you may as well get another set of pads and take those rotors off. i am not sure if that will cause the squeeling, but it will catch on fire if you are not careful.
usually when the pads squeek, it is because they are junky pads. i would take them off and make sure they aren't destroying your rotors. they could be too hard a pad for the rotors too.
i guess if i were you i would just take the tires off and check out the pads and rotors just to see if they are not wrecked.
Old Jan 14, 2002 | 05:19 PM
BlackAxis's Avatar
Default Re: Brake Rotors/Pads issue (crxplus)
hmmm
Okay, thanks I'll try that. I did clean off the rotors before I installed them.
[Modified by BlackAxis, 2:20 AM 1/15/2002]
Old Jan 14, 2002 | 05:25 PM
BlackAxis's Avatar
Here is the pic, I think I reasslembed everything correctly, like I said this is my first time doing this.
Old Jan 14, 2002 | 06:34 PM
pelotudo's Avatar
There's your problem right there...you're using a can of brake cleaner to hold up your car
j/k
looks good
Jonathan
Old Jan 14, 2002 | 06:35 PM
BlackAxis's Avatar
Default Re: Brake Rotors/Pads issue (PeloTudo)
Thats one strong can!!!!!
Old Jan 14, 2002 | 07:01 PM
TurboSedan's Avatar
New User
ROFL! Damn, they don't make cans like that anymore do they!
Looks like you cleaned it very well, should be ok.
H2290
10
Jul 28, 2006 01:56 PM
kornerk12
Apr 27, 2006 01:17 PM
::MYCORD::
Jul 11, 2004 03:00 AM
BURT REYNOLDS
May 13, 2003 07:37 PM
