obd0 to obd1
Old Jan 29, 2005 | 07:40 PM
mainline69's Avatar
Default obd0 to obd1
I have a 90 integra with a B16 out of a JDM 99 civic si and i have it wired in and i had it running with all obd0 computer and distributer. i changed the distributer back to obd2 and i baught obd0 to obd1 conversion harness. Will this work on my setup ??
Old Jan 30, 2005 | 08:12 AM
hondaguyef's Avatar
Default Re: obd0 to obd1 (mainline69)
Yes but, you will also need a 4 wire o2 sensor and you will have to make an adapter harness for your distributor(best way IMO).. What harness did you purchase?
Phil
Old Jan 30, 2005 | 08:49 AM
Type R CivIc's Avatar
Default Re: obd0 to obd1 (hondaguyef)
use ur stock ecu and ur obd 1 harness it will work but u need to wire up the vtech wires..
Old Feb 9, 2005 | 05:45 AM
mainline69's Avatar
I had the obd2 engine sliced into the obd0 harness and it ran like with the obd0 distrubuter and ecu. I baught a new ecu and put back on the obd2 distributer that came with the car. The ecu hooks up to the car through the boom-slang harness that i baught. I recently finished all of the wiring and conversion. Now the car will not start. I dont know what it could be. I have spark and injection, and it spits and sputters, but no turn over. I sent it away because maybe i just couldn't get the timing right. So if you have any other suggestions that i could tell the mechanic please let me know. Thank you.
Old Feb 9, 2005 | 06:35 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
sometimes if a block has been sitting for a while, they will take a while before they'll start up. after i finished my swap it didn't want to start up. i let it sit overnight, tried it again the next day, and it started right up.
jarhead90crx
12
Aug 5, 2011 07:06 AM
lejeaune
Apr 21, 2010 09:31 AM
bobbyisking
Jul 7, 2008 09:22 AM
apice
Mar 19, 2008 03:35 PM
soundman
10
Nov 14, 2003 07:59 PM
