Shifting Problems
Old Jan 29, 2005 | 06:47 PM
HPCO$T's Avatar
Default Shifting Problems
I have a 1999 Civic Si. I noticed last night for the first time when I would go into 4th gear Clutch all the way in just driving it would stick a little and coming out of the gear as well. I know my 3rd gear syncro is kicking the bucket but what could be with the 4th gear. Bent shift Fork? It sdoesn't help if you rev match or anything it sticks. It is bugging the hell out of me any ideas? Also I am not one to work on trannys I hate it How much you think I am looking at to fix this and fix my 3rd gear syncro issue.
Thanks for the help.
-Ryan
Old Jan 29, 2005 | 06:54 PM
Aphelion's Avatar
Default Re: Shifting Problems (bluesol94)
I think you are probably looking at a new tranny. At least that's what everyone has been telling me (94 si with 3rd gear grind).
Old Jan 29, 2005 | 06:55 PM
HPCO$T's Avatar
Also For got to add feels the same when car is off as well The part about sticking in only 4th gear
Old Jan 29, 2005 | 07:14 PM
HPCO$T's Avatar
A new tranny at only 74,000?
only issue is barily grind in third gear and then this ****
Really think a New tranny?
Old Jan 29, 2005 | 07:47 PM
HPCO$T's Avatar
Help?
Old Jan 30, 2005 | 01:18 PM
HPCO$T's Avatar
Bump for help
Old Jan 30, 2005 | 01:24 PM
Spoolin93si's Avatar
Default Re: (bluesol94)
I bought some Gear speed carbon synchros for my tranny and i'm only paying $150 to get them put in.
Old Jan 31, 2005 | 06:01 AM
HPCO$T's Avatar
humm not that bad at a shop
Old Jan 31, 2005 | 07:13 AM
runs11's's Avatar
im not sure but i think you'll be looking at around 500 for a basic rebuild on a honda tranny your prolly better off just asking your friend to find another b16 trans
Old Jan 31, 2005 | 07:15 AM
Ricey McRicerton's Avatar
Default Re: (runs11's)
Before you tear the whole thing down, I'd recommend trying som GM Synchromesh FM.
If you do tear it down it'll be much cheaper than getting a new tranny.
Old Jan 31, 2005 | 07:54 AM
Deemeetree's Avatar
Electrician
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluesol94 &raquo;</TD></TR><TR><TD CLASS="quote">A new tranny at only 74,000?
Really think a New tranny?</TD></TR></TABLE>
Mileage DOES NOT matter on transmission life. It all depends on how you drive it that ultimately tells you whether or not your transmission will grenade or not.
Old Jan 31, 2005 | 09:06 AM
HPCO$T's Avatar
Default Re: (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">Before you tear the whole thing down, I'd recommend trying som GM Synchromesh FM.
If you do tear it down it'll be much cheaper than getting a new tranny.</TD></TR></TABLE>
I did Syncromesh at the tranny change that's what I stuck in there. Helped shifting and grind a little .How much do you think I am lookin at to do a fix on the tranny if Syncros are bad in 3rd and 4th ear and shift fork is gone? Anyone know?
Old Jan 31, 2005 | 09:19 AM
d15z6's Avatar
3rd and 4th gear hawe same syncro so that might be a problem.
I hawe a 3rd gear problem when I shift ower 6000rpm, from 2 to 3rd I feal the hrshh but the 4th is ok.
Old Jan 31, 2005 | 09:23 AM
HPCO$T's Avatar
Hum Didn't know used same syncro?
Old Jan 31, 2005 | 01:16 PM
HPCO$T's Avatar
Could that be it
Old Jan 31, 2005 | 01:25 PM
mucter's Avatar
they do not use the same synchro, they use the same shift fork. because of the design of honda's manual tranny's its impossible for it to use the same synchro... its something related to your shift fork on 3/4th gear
Old Jan 31, 2005 | 01:41 PM
PreludeDude96's Avatar
Default Re: (mucter)
Exactly, couldn't have said it better
Old Jan 31, 2005 | 05:29 PM
HPCO$T's Avatar
Cool , Any one have an idea on cost of this
Old Feb 1, 2005 | 09:53 AM
POE's Avatar
POE
and arm and a leg
Old Feb 1, 2005 | 11:37 AM
HPCO$T's Avatar
2 of them I bet. GAY!!!
Big Rhag
Transmission & Drivetrain
Oct 10, 2014 10:31 AM
vietnogi
Feb 2, 2006 11:36 AM
standaloneaccord
Oct 7, 2005 09:03 AM
cvc323
Jul 29, 2004 03:07 PM
charjacq
Jul 27, 2004 01:13 PM
