How do I go about finding cam caps
Old Jan 29, 2005 | 04:58 PM
DrewDown's Avatar
Default How do I go about finding cam caps
Well I found a good deal on a low mileage B18b head only problem is its missing the cam caps. Is there Anyway I can find some that fit? Or should I just spend a little more and buy a complete head since I havent spent money yet. Also is there any chance the ones from my b18a will work? Thanks in advance.
Old Jan 29, 2005 | 06:19 PM
B20TDC2's Avatar
Default Re: How do I go about finding cam caps (DrewDown)
cam caps are hard to come buy acura willnot sell them seperate.
Old Jan 29, 2005 | 07:00 PM
mmuller's Avatar
Mad Scientist
i would just look around the classifies for a broken head that has the caps on it.
if you really want to i could prolly dig a set up from an old b18b head that i have
Old Jan 30, 2005 | 08:16 AM
T.J.'s Avatar
Dam i wish you would have posted this last week, I just through out a set of caps with the bolts.
Old Jan 30, 2005 | 10:10 AM
DrewDown's Avatar
Bummer I would have taken those off your hands T.J. But will any cam caps fit off a b18b? I thought they weren't all the same.
Old Jan 30, 2005 | 10:52 AM
NJIN BUILDR's Avatar
When the heads are manufactured they mount the caps then bore the hole for the cams.Honda is good at locating this hole but it doesn't off much between two heads to have a problem switching caps.Lots of people have gotten away with switching caps and have it work.On a LS head I wouldn't waste my time trying.Just find another head.
Glenn
Old Jan 30, 2005 | 06:17 PM
DrewDown's Avatar
Default Re: How do I go about finding cam caps (NJIN BUILDR)
I guess I will probably just look for a different head then instead of bothering to look for a set of cam caps. Thanks for the help.
Old Jan 30, 2005 | 09:35 PM
fabs's Avatar
i have a spare head if u need one.
Old Jan 31, 2005 | 09:17 AM
bigTom's Avatar
Default Re: How do I go about finding cam caps (fabs)
caps are mated specifically to a head... like stated above... honda bores and hones the holes for the cams with the caps on the head which as much as there all the same... there is always a slight differance in the bore location... u cannot just go and use differant caps... u might be lucky and it will work... i dont personnally reccommend it
Old Feb 8, 2005 | 07:13 PM
Bigplans06's Avatar
drew i think zach with the b16 integra has a spare Ls, ill ask him if he wants to get rid of it if you want me to, i think he was just going to throw it out anyways.
crispy93
Mar 8, 2007 07:17 PM
HossRacingF22B1T
Feb 20, 2007 09:25 AM
Wazup
May 2, 2006 07:47 PM
KTeller8
Mar 13, 2004 11:59 PM
CrazyKoreanCrx
May 31, 2003 02:05 PM
