99 civic si amp install question
Old Jan 29, 2005 | 04:57 PM
cjmoral's Avatar
Default 99 civic si amp install question
I mhave a 99 civic si and am trying to put in an amp.I need to know where the hole in the firewall is and what wire on my wiring harness connects to the remote power on wire to the amp
Old Jan 30, 2005 | 09:39 AM
civic_speed99's Avatar
Default Re: 99 civic si amp install question (cjmoral)
The hole in the firewall is right below the battery, it is the main harness for the car. You will have to take out the battery and battery tray to make your like easy. This hole will come right inside the footwell on the passenger side. For the remote wire, if you have a aftermarket CD player it will be the blue wire, not sure on the stock harness though.
Old Jan 31, 2005 | 12:10 AM
Icyrain's Avatar
Default Re: 99 civic si amp install question (civic_speed99)
Yup, just did this with my 98. If you're good and have enough petroleum and some skill you can get the rubber to stretch and get the power cable through without any cutting. I did this with an 8 gauge cable.
Old Jan 31, 2005 | 06:52 AM
CooBlueDAB's Avatar
Default Re: 99 civic si amp install question (Icyrain)
http://gozips.uakron.edu/%7Eda...h.htm
that should have pics that will help you... Its a 2000 EX, but they are the same chassis basically correct? So check that page out, and you should be able to find good places for all the wires to run as well as where to run them in dash. If you have any trouble, I might be able to find more pics, and such, or describe something unclear to you
Old Jan 31, 2005 | 07:01 AM
That is a good write up, but if you don't want to chance distortion, run the rcas down the middle under the carpet. The main harness to the trunk runs down the drivers side panel.
Old Jan 31, 2005 | 07:21 AM
CooBlueDAB's Avatar
Default Re: (civic_speed99)
aye it does, but ive yet to get any distortion, and those wires seem to be shielded pleanty. It is also a fairly easy place to put it, short of removing the carpet you know?
If he wanted to keep it easy, he could run the power cable on the other side.. but you want that as short as possible... so running it another 5-6 feet through the dash would not work out too well as far as I know.
Ive got longer cables than I need, so I should be more suseptable to drop and interferance... But I have none yet, so I can vouch for these locations working great. At least with my wire sets.
Old Jan 31, 2005 | 08:02 AM
fcm's Avatar
fcm
Old Fart
Default Re: (CooBlueDAB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CooBlueDAB &raquo;</TD></TR><TR><TD CLASS="quote">aye it does, but ive yet to get any distortion, and those wires seem to be shielded pleanty. It is also a fairly easy place to put it, short of removing the carpet you know?
Ive got longer cables than I need, so I should be more suseptable to drop and interferance... But I have none yet, so I can vouch for these locations working great. At least with my wire sets.</TD></TR></TABLE> I never have to pull the carpet to run the RCAs, I just pull the consol, use an old ant. mast as a snake to pull the RCAs through and under, the foot or so, of carpet between the back of the consol and the back seat, and just like the power keeping the RCAs short, cant hurt. 94
Old Jan 31, 2005 | 08:17 AM
Default Re: (fcm)
Yeah I never actually pulled the carpet. U just took out the center console and fished it under throught the several opening under there. But that it just my opinion because it saved my about $10 on the rcas.
purposebuilt
Audio / Security / Video
Dec 6, 2019 04:48 PM
vanberge
Mar 3, 2011 08:02 AM
themunchkinman
Apr 17, 2008 08:33 AM
ablack934doorcivic
Feb 21, 2005 05:25 PM
SIMATIC
Jul 2, 2003 07:41 AM
