harness helpppppppppp
ok im doing a d16 swap in a 90 hatch std and i got the conversion harness and i had a couple of quess.....ok the harness didnt come with any instructions and i was wondering about the injector wires are the already switched on my new harness,do i still need to cut the harness in my car no and run them and what about the cylinder position sensor wires some one pleaseeeeeeeeeeeeee help if someone could maybe scan and make a copy of there harness instructions thanks
who made the harness and pics would help i have built these before. how many wire/s do you have coming off the new harness that are not part of an ecu plug.
ok so i figured out about the wires on the pig tail i understand that what im trying to figure out is do i need to go ahead and do the mpfi cut the wires on my harness and switch them out and so on and so forth... or are the wires already switched in my conversion harness??? i dont think they are i guess that the harness is just so i can run v-tec and the o2 sensor!!!
again who made the harness and if they made it right the wires should be fliped for cam angle sensor. if i don't know who made it i can't tell you about the wiring and how it was done
Sounds like you bought an OBD0-OBD1 conversion harness.
What you need to do first is click this link.
http://www.fourthgenhatch.com/mpfi.html
Next what d16 do you have?? d16a6,d16a1,d16z6,d16y7,d16y8???
CRX91SE
Mar 31, 2011 10:29 PM
JDM_EK_JOE
Oct 17, 2007 02:23 PM
bossman032
Jun 28, 2003 03:33 PM
