Aftermarket steering wheel and SRS light
Old Jan 14, 2002 | 11:40 AM
servion's Avatar
Default Aftermarket steering wheel and SRS light
I just installed a momo wheel into my 5th getn hatchback, and I pulled the fuse for the SRS system and the light is still on.... anyone know how to disable this? Also, I couldn't figure out how to hook up the horn since the calbe reel has to be removed... any thoughts?
Old Jan 14, 2002 | 01:03 PM
DIZASTICAL's Avatar
Default Re: Aftermarket steering wheel and SRS light (servion)
take ou the gauge cluster and remove the light for the srs . that is the only way to fix that problem . as for the horn . i had to hook up a funky contraption to get it to work with the aftermarket wheel . but it works great . i have a 99 civic type r wheel and i used that horn button . it is hard to explain how to do it . i will take pics or post a diagram !
Old Jan 14, 2002 | 01:05 PM
Mr. Thunderlips's Avatar
yeah, what he said...the only way i know of is to pull the SRS light outta the cluster...i had to do that with my JDM DC wheel...
Old Jan 14, 2002 | 01:14 PM
servion's Avatar
Default Re: Aftermarket steering wheel and SRS light (Slo_Teg)
hm... I was reading around on th web, and some people with preludes were hooking up 2ohm resistors somewhere for the srs light... anyone ever heard of that for an eg?
Old Jan 14, 2002 | 01:26 PM
DIZASTICAL's Avatar
i would not screw with the wires just unplug the light . it will save you a lot of hassel . i think that they are using a resistor to shut the light off but still use the passenger side air bag ??????????????? not sure though . sorry!
Old Jan 14, 2002 | 01:39 PM
servion's Avatar
Default Re: Aftermarket steering wheel and SRS light (DIZASTICAL)
cool... thanks. If you could do a diagram or post some pics of your horn setup, that would be great.
Old Jan 14, 2002 | 01:54 PM
DIZASTICAL's Avatar
i will try to explain this to you , but bare with me , it is not easy !
you have to make a contact to touch the bronze metal part of the steering hub . i used a spring . because the spring does not put so much pressure on the steering wheel that you can tell a difference in the feel while turning . i soldered a wire onto the spring and ran it under the dash to the pin on the air bag harness that was used for the horn . it is the pin all the way to the left on the yellow plug with the ribbon harness on it . as soon as that wire sees ground the horn honks . i made a bracket to hold the spring inside of the steering column so it does not move at all but always has contact with the hub . then hook up the wires the way that they should be on the steering wheel . sorry for the confusion but its not an easy thing to describe .
erck
Jun 8, 2007 07:34 PM
Rene M
Oct 11, 2006 02:43 PM
mikehawkBUiLT
36
Aug 21, 2004 09:55 PM
Marauder
Apr 11, 2003 03:26 PM
