Clutch leaking...help please
Old Jan 29, 2005 | 02:03 PM
EJ8 GSR-T's Avatar
Default Clutch leaking...help please
hey so ive been loosing hydrolic fluid like crazy, and i finally traced the lead to here....and tried to use gasket maker to seal it up but very bad idea i have no idea what i was thinking...so first off what is this? and how do i stop it from leaking?
Old Jan 29, 2005 | 02:25 PM
TeamNextGenChris's Avatar
Default Re: Clutch leaking...help please (userdead626)
what you're trying to seal is simply a dust boot-fluid SHOULDN'T be in there.you need to replace your slave cylinder.
Chris
Old Jan 29, 2005 | 03:53 PM
EJ8 GSR-T's Avatar
how do you get the hydrolic line out of the main (black) housing?
Old Jan 29, 2005 | 04:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by userdead626 &raquo;</TD></TR><TR><TD CLASS="quote">how do you get the hydrolic line out of the main (black) housing? </TD></TR></TABLE>
you just unscrew the pipe fitting right in the middle of your circle.
chris
Old Jan 29, 2005 | 04:35 PM
RedlinedVTEC's Avatar
Flare nut wrench or a regular wrench will work as well, but I can't remember the size off the top of my head. Also to make certain it is the slave cylinder leaking and not the hardline, have someone pump the clutch pedal while you look for the source.
Old Jan 29, 2005 | 04:38 PM
RotiEatter's Avatar
Ditto
Default Re: Clutch leaking...help please (RedlinedVTEC)
its a 8mm, use a flare-nut wrench so you dont strip it
Old Jan 29, 2005 | 08:48 PM
EJ8 GSR-T's Avatar
cool, thanks guys 15$ later and its all fixed up!
Old Jan 29, 2005 | 09:03 PM
eg_type_r93's Avatar
10mm pipe wrench, 8mm is the bleeder nipple and turn towards the block not the fan.
Old Jan 29, 2005 | 09:31 PM
Calvinator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedlinedVTEC &raquo;</TD></TR><TR><TD CLASS="quote">Flare nut wrench or a regular wrench will work as well, but I can't remember the size off the top of my head. Also to make certain it is the slave cylinder leaking and not the hardline, have someone pump the clutch pedal while you look for the source.</TD></TR></TABLE>
I cannot stress that enough, to only use a flare nut wrench on those clutch and brake line fittings.
Old Jan 29, 2005 | 09:44 PM
JSJ EG6's Avatar
Default Re: Clutch leaking...help please (xtremeazian)
are d and b series slave cylinder the same?
Old Jan 30, 2005 | 05:04 AM
Default Re: Clutch leaking...help please (JSJ EG HATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSJ EG HATCH &raquo;</TD></TR><TR><TD CLASS="quote">are d and b series slave cylinder the same?</TD></TR></TABLE>
yes.probably worth the money to get a new one though-the seals in the slave cylinder are prone to failure if using a heavy duty pressure plate,and installing one in questionable condition may leave you with another failed part a lot sooner than you planned.
Chris
Old Jan 30, 2005 | 05:51 AM
loco_ese's Avatar
Default Re: Clutch leaking...help please (TeamNextGenChris)
you can purchase a rebuild kit (a spring and new piston cup) from NAPA for around $5.63 and rebuild it yourself, not hard at all.
Old Jan 30, 2005 | 07:43 AM
ironlung78's Avatar
Default Re: Clutch leaking...help please (loco_ese)
a new slave cylinder is only around $50.00 not really worth rebuilding in my opinion because its just going to leak again.
2 bolts and the fitting from the metal line to remove it..
make sure you bleed your clutch correctly also when your done!!!
Old Jan 30, 2005 | 10:26 AM
EJ8 GSR-T's Avatar
Default Re: Clutch leaking...help please (sidesi)
Yeah mine was like 15.50 or soemthing so a rebuild kit wouldnt be worth it. Also whats the correct process for bleading the system?
Old Jan 30, 2005 | 11:09 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by userdead626 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah mine was like 15.50 or soemthing so a rebuild kit wouldnt be worth it. Also whats the correct process for bleading the system?</TD></TR></TABLE>
very similar to bleeding brakes.fill the reservoir up with new brake fluid,and attach a clear hose to the bleed nipple,with the hose running into a catch can.slightly open the bleed screw and pump the pedal until no air runs out.keep an eye on the reservoir to make sure you don't run out of fluid.close the bleeder and see if the pedal feels good.you can also start the car and make sure the car shifts in and out of gear easily.if you have any problems,keep bleeding.
Chris
213374U
Feb 20, 2013 06:03 AM
rhdins
Nov 3, 2009 03:22 AM
kelvinchau25
Jan 17, 2008 08:34 AM
9deuce9rr
May 28, 2004 11:28 PM
90babyblue
Apr 29, 2004 09:07 AM
