CAM lateral movement?
Old Jan 29, 2005 | 01:27 PM
rjay8604's Avatar
Default CAM lateral movement?
Well i was just looking at the cams (b16) and noticed there doesn't seem to be any perpendicular surface on the cams to limit lateral movement, i see a spot on the head where it look like oil is fed to one thrust surface but where is the opposite facing surface for thrust towards the crank pulley side of the engine. Guru's lets hear it.
Old Jan 29, 2005 | 02:08 PM
drdisco69's Avatar
Default Re: CAM lateral movement? (rjay8604)
I'm no guru, but on the end of the cams by the back of the motor, there are thrust surfaces about 10mm from the end. It's a ridge about 10mm high and 5mm wide and fits into a slot in the cam cap on the end.
JDM MOST WANTED
Oct 20, 2009 10:08 AM
vinuneuro
29
Nov 1, 2007 11:08 AM
BADGUYNY
Oct 6, 2007 04:14 PM
Sassafrass
Sep 11, 2003 08:05 AM
Twigster311
Jul 5, 2003 09:17 AM
