Hi-flow car for my 00 Civic coupe...
Old Jan 29, 2005 | 11:48 AM
LvN's Avatar
LvN
Default Hi-flow car for my 00 Civic coupe...
I have a B18c w/ a mugen 4-1 header w/ 2.5 collector, stock civic cat and stock civic exhaust. I'm planning on replacing the catalytic converter for a Hi-flow cat and put a catback exhaust system (Apexi WS). My question is, should I get a 2.5in piping all around or should I keep it at 2.25in? Also, does a Hi-flow cat help or just a waste of money?
Old Jan 29, 2005 | 12:06 PM
civictildeath's Avatar
Default Re: Hi-flow car for my 00 Civic coupe... (blkcivicpn0i)
i would stick with 2.5 pipes and the hi flow cat will add some power though some do not pass emissions test
Old Jan 29, 2005 | 01:41 PM
LvN's Avatar
LvN
Default Re: Hi-flow car for my 00 Civic coupe... (civictildeath)
So a 2.5 inch piping will benefit me more than a 2.25. Would I gain or lose power. It's a stock motor with i/h/e. I'll be adding a catback soon. I just wanna know if I'd benefit from a bigger piping. Also, does anyone know what size piping a stock ITR has, from header to exhaust? Thanks
Old Jan 29, 2005 | 02:37 PM
Lil Corb's Avatar
how did you get your 2.5" collector to match the stock cat?
Old Jan 29, 2005 | 03:06 PM
LvN's Avatar
LvN
Default Re: (Lil Corb)
Used a donut with a 2.25" inch hole. Basically converted it to 2.25"
Old Jan 29, 2005 | 04:35 PM
trooper0641's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkcivicpn0i &raquo;</TD></TR><TR><TD CLASS="quote">So a 2.5 inch piping will benefit me more than a 2.25. Would I gain or lose power. It's a stock motor with i/h/e. I'll be adding a catback soon. I just wanna know if I'd benefit from a bigger piping. Also, does anyone know what size piping a stock ITR has, from header to exhaust? Thanks</TD></TR></TABLE>
Overall you will eventually have more hp with a 2.5" than a 2.25". The reason why the ITR has a 2.5" header to a 2.25" piping is because it was made for circuit racing. With a 2.25" you would have better throttle response, pedal pressure, and the power needed for low rpm turning where you need the constant pressure. If you are into straights you should go for the 2.5"...you will have more power...probably somewhere around a 1-2 whp more than a 2.25. Maybe even 3hp! WHO KNOWS?
Just image your piping, being simaliar to a turbo. The smaller the faster the spool, the bigger...the slower the spool but with the bigger high end.
Old Jan 29, 2005 | 07:11 PM
LvN's Avatar
LvN
Default Re: Hi-flow car for my 00 Civic coupe... (trooper0641)
Thanks!! 2.5" it is.
Old Jan 29, 2005 | 07:40 PM
NAgixxer's Avatar
id definately get a hiflow cat though too.
they can be had for quite cheap at http://www.kteller.com i got mine there and was very pleased with it.
mr devious illusions
Jun 5, 2006 05:55 PM
one slow coupe
Jan 18, 2005 10:29 AM
silentkill03
Nov 5, 2004 02:09 AM
JDMvtecDRAGSTA
Jan 22, 2003 05:16 PM
