P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage HELP!!
Old Jan 29, 2005 | 11:26 AM
slickciv's Avatar
Default P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage HELP!!
MY CAR THREW THIS CODE AND I NEED THIS CODE AND I NEED TO KNOW HOW TO SOLVE THE PROBLEM. MY CAR IS GETTING REALLY BAD GAS MILEAGE AND IS RUNNING KINDA ROUGH AND HAS PROBLEMS TAKING OFF SO ANY HELP WOULD BE APPRECIATED.
Old Jan 29, 2005 | 11:55 AM
TeamNextGenChris's Avatar
Default Re: P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage HELP!! (slickciv)
jesus,turn off the caps,and learn how to write a sentence!
there is a simple troubleshooting procedure in a $10 shop manual from an auto parts store.there should be 5v on one wire,ground on one and a signal back to the ECU on one.the signal voltage varies with vacuum,up to 5v.if there's only 5v on the feed wire,and more than 5v on the signal,the sensor is bad.if there's more than 5v on the feed wire,you're either picking up voltage from a short to a 12v wire,or the ECU is sending too much current(doubt it since all the 5v sensors get their feed from the same circuit).
Chris
Agent_EM1
23
Dec 29, 2008 09:54 PM
Groove_D
May 27, 2006 11:40 AM
2000civicsi
Oct 15, 2005 07:09 PM
