Sub $900.00 Coilovers.
Old Jan 29, 2005 | 10:48 AM
jbell's Avatar
Default Sub $900.00 Coilovers.
So I've been looking for the best coilover setup for an EG that wont leave me completely broke.
It seems that Omnipower is my best bet, however they are not dampening adjustable.
I know there are tien basics, D2, Tanabe Sustec Pro S-S Type II Coilover Kit, Tokico Illumina Coilovers, and Tanabe Sustec Pro S-OC Type-II Coilovers
they seem like they would be good, but i would really like to hear any opinions on what is best.
basically, im looking for the best STREET setup. my car will never be tracked, so i want something that i can dump the car with and not be slamming all over the place.
tia.
Ricey McRicerton's Avatar
Default Re: Sub $900.00 Coilovers. (jbell)
Koni Yellows + Ground Controls.
550ish for the shocks (which have a lifetime warranty)+ 300ish for the coils.
Old Jan 29, 2005 | 10:49 AM
b18bEG's Avatar
I have the tanabes and they are great I hve no complaints.... i see skunk2 now has decently priced kits, might wanna look into those as well..
Old Jan 29, 2005 | 10:50 AM
jbell's Avatar
Default Re: Sub $900.00 Coilovers. (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">Koni Yellows + Ground Controls.
550ish for the shocks (which have a lifetime warranty)+ 300ish for the coils.</TD></TR></TABLE>
would this really be better than a full coilover system? dont full coils like omnipower have larger spring travel?
Old Jan 29, 2005 | 10:52 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbell &raquo;</TD></TR><TR><TD CLASS="quote">
would this really be better than a full coilover system? dont full coils like omnipower have larger spring travel? </TD></TR></TABLE>
I honestly don't know much about the OMNI's, but I can damn sure vouch for the Yellows and GCs. You can get custom rates on the GCs for 329 and with the Yellows you have a lifetime warranty.
Old Jan 29, 2005 | 11:42 AM
jbell's Avatar
i had sleeve coilovers before and i hated them, the spring is only a few inches tall, where as the stock or after market springs are much taller. it makes them stiff as all hell.
Old Jan 29, 2005 | 11:47 AM
chris_c's Avatar
seriously, spring for the extra 45 bucks and get the tein ss dampers. it's like what, a week of skipping lunch.
i too was weary about spending close to a grand on suspension for a $3000 del sol but it was by far the best $ spent on the car. all doubts will be gone one you go for your first ride with them. the only complaint i have about them is that they are a tad soft, BUT for an all street car you will be fine...
Old Jan 29, 2005 | 11:56 AM
EM2Civic's Avatar
I bought the omnipower cuz they are my first set of full coilovers and when I out use them i'll look into getting either Tein SS, Tanabe S03 etc with dampening and rebound adjustable.
Old Jan 29, 2005 | 12:18 PM
integlspwr2k's Avatar
Default Re: (EM2Civic)
i have the d2's with custom rates (hella stiff) and i love them.
Old Jan 29, 2005 | 01:06 PM
jbell's Avatar
Default Re: (integlspwr2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlspwr2k &raquo;</TD></TR><TR><TD CLASS="quote">i have the d2's with custom rates (hella stiff) and i love them.</TD></TR></TABLE>
do you use them for street driving? what are the rates?
Old Jan 29, 2005 | 01:09 PM
Default Re: (jbell)
do you use them for street driving? what are the rates? </TD></TR></TABLE>
i use them for daily driving all the time and the rates are 1000lbs rear and 800lbs front.
Old Jan 29, 2005 | 01:11 PM
jbell's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlspwr2k &raquo;</TD></TR><TR><TD CLASS="quote">i use them for daily driving all the time and the rates are 1000lbs rear and 800lbs front.</TD></TR></TABLE>
hrm. they sound decent. any problems with bouncy-ness or anything, im strongly considering them.
although, i did find omnpowers for the eg, under $700...
Old Jan 29, 2005 | 01:13 PM
Maginnovision's Avatar
I got koni yellows and skunk2 adjustable springs for 900.
Modified by Maginnovision at 6:33 PM 1/29/2005
Old Jan 29, 2005 | 01:14 PM
Default Re: (jbell)
although, i did find omnpowers for the eg, under $700... </TD></TR></TABLE>
no bouncey ness if they are on full soft. yOU need to match the shock to the spring rates.
i would go for the d2's for they have damper adjustabilty. Omni's dont, and when ever you lower or raise a car, you need to adjust damper.
Old Jan 29, 2005 | 01:17 PM
4 Skunk2 Adjustable Springs 4 Tokico Adjustable Illumina Struts 700$
http://www.modacar.com/product...DASUP/
Old Jan 29, 2005 | 03:08 PM
jbell's Avatar
Default Re: (Maginnovision)
i dont want sleeved coilovers!!!!
Old Jan 29, 2005 | 03:47 PM
piscorpio's Avatar
I always reccomend APEXi WS coilovers whenever someone asks this question. I had them for a few years, just for street driving, and I was very happy with them. Noticably stiffer ride than stock, but not jarring or uncomfortable on bumpy roads. Never bouncy feeling and never wore out over the few years I had them. I also had a ST rear sway bar, and the combo worked very nicely on my EK as well as my EG. Only complaint is they can be susceptible to rust, but I doubt many sub-$900 coilovers will be constructed of aluminum or other non-corroding material. Just make sure to take the time to clean them every now and then, probably lube them too. You should be able to get them for less than 900 if you shop around.
Old Jan 29, 2005 | 04:27 PM
deeksmooth's Avatar
Default Re: Sub $900.00 Coilovers. (piscorpio)
well you're looking to "dump" the car without hitting the ground, that's not going to happen. i have tanabe sustec pro SS coils on my civic hatch and i love them for daily driven, i want some higher spring rates though and a comptech rear tie/sway.
anyone up for donating? lol
Old Jan 29, 2005 | 04:41 PM
jbell's Avatar
Default Re: Sub $900.00 Coilovers. (deeksmooth)
bah. does anyone make a decent coilover system with the camber adjustable tophat????
i think im going to get
tein basics, and the camber top plate.
Old Jan 29, 2005 | 04:48 PM
I'd say spend a little extra and get the tein flex, then when you can get the motors/controller.
Old Jan 29, 2005 | 04:51 PM
jbell's Avatar
little extra? they are $1400
Old Jan 29, 2005 | 04:59 PM
jbell's Avatar
Default Re: (jbell)
hrm... maybe i'll take my chance with megan racing....
http://cgi.ebay.com/ebaymotors...&rd=1
Old Jan 29, 2005 | 05:03 PM
95dxhatch's Avatar
ive ridden in a car with tein flexs before with the dampening as stiff as they could go and wasnt impressed. so i can only assume that the basics and SS's are even worse. dont know much about the other setups but i've been looking into omnipowers myself. thats the way i'll be going.
i have adj. dampening shocks right now (agx) and to be honest with you i never touch the setting so adj. dampening isnt a huge concern for me.
Old Jan 29, 2005 | 05:08 PM
jbell's Avatar
Default Re: (95dxhatch)
i think im gonna get the megan racing ones.
their products are supposed to be good for their price.
plus.. its adjustable, with camber tophats.
Old Jan 29, 2005 | 05:09 PM
Default Re: (jbell)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbell &raquo;</TD></TR><TR><TD CLASS="quote">hrm... maybe i'll take my chance with megan racing....
those dont look like a civic application. it looks more for a 240 or something.
looks like its simliar to the d2 seutp. i rather get teh d2s and save some money.
