98 ITR - what chip do you like or worked well for you ?
Old Jan 29, 2005 | 08:03 AM
m0t0rhead's Avatar
Default 98 ITR - what chip do you like or worked well for you ?
'98 CW Integra Type-R
I've put on a few chosen parts that I like. I'm looking to upgrade my fuel and ignition maps, as well as rev and speed limit to take advantage of my upgrades.
What programs have worked well for you with similiar mods ? I don't really think I want to shell out more than 300-400 dollars. What are you opinions ?
Here is what I have on it currently.
Comptech Ice-box and intake
JDM 4-1 Header w/heat shields
Magnaflow resonator
Apex-i N1 catback
AEM fuel pressure regulator & guage
Unorthodox Racing cam gears
Old Jan 29, 2005 | 08:24 AM
Chris F's Avatar
Default Re: 98 ITR - what chip do you like or worked well for you ? (Escobar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Escobar &raquo;</TD></TR><TR><TD CLASS="quote">I've put on a few chosen parts that I like. I'm looking to upgrade my fuel and ignition maps, as well as rev and speed limit to take advantage of my upgrades.
What programs have worked well for you with similiar mods ? I don't really think I want to shell out more than 300-400 dollars. What are you opinions ?</TD></TR></TABLE>
IMO:
You can almost budget a VAFC plus some dyno tuning time. You need to dyno tune it anyway to take advantage of the cam gears. So get something that'll let you do some tuning, rather than an off-the-shelf program that might not work that well for you.
It won't bump your rev limit, but are you really sure you wanted to do that anyway?
-Chris
Old Jan 29, 2005 | 08:26 AM
ZygSpeed's Avatar
... what Chris F said!
Old Jan 29, 2005 | 08:45 AM
Chris F's Avatar
Default Re: 98 ITR - what chip do you like or worked well for you ? (zygspeed)
Let me just add, if I was stuck on an island with no dyno, I might check out Kenji's ECUs.
Kenji:
https://honda-tech.com/zero...=2322
His ECU in a Type R or two: (my search revealed 158 results)
https://honda-tech.com/zerothread?id=1094670
https://honda-tech.com/zerothread?id=1006238
ECU suggestions for mainly stock set up...USDM, JDM, Kenji, OBD1, Other?
https://honda-tech.com/zerothread?id=1085231
Old Jan 29, 2005 | 03:21 PM
m0t0rhead's Avatar
Thanks.
civic gtr
Nov 13, 2004 09:50 AM
Dammit_Dan_954
Jun 4, 2004 02:20 PM
AutoxVet
Jun 23, 2003 08:34 PM
Tyson Ballou
Mar 19, 2002 01:38 PM
