very wierd bogging vtec problem | video and dyno graph inside
Old Jan 29, 2005 | 03:06 AM
milano2kdc2's Avatar
Default very wierd bogging vtec problem | video and dyno graph inside
before i say anything, here is my setup
00 gsr
skunk2 intake manifold
aem 3" short ram
skunk2 stage 1 cams
skunk2 cam gears, +2 intake/+0 exhaust
jdm 4-1 header
test pipe
buddy club spec 2 exhaust
fpr set at 50 psi with vacuum hose on, 58 psi with it off
ih8ricerz mild j's racing prog
ignition timing is at 17 degrees
fields vtec controller with the following fuel settings
rpm: fuel settings
1: -6%
2: -5%
3: -4%
4: -4%
5: +0%
6: -3%
7: -4%
8: -6%
vtec x-over at 5400 rpm
vtec bogging video
http://home.comcast.net/~ken-c...g.wmv
that is a 3rd freeway pull, but it happens in all gears. when the car is bogging, the car shakes hard as if i was tapping the gas.
dyno graph:
It was doing this before tuning, but i thought it was just because my car was untuned. Apparently the car didn't act wierd like this on the dyno, I duno why it didn't. It started bogging like that after i left the shop when i was smashing outside. in the cold rainy weather (if that helps). I can't think of why it does this, dyno tuning shouldve fixed it?
Whats the problem here?
Thanks in advanced for the help
Modified by milano2kdc2 at 8:02 PM 1/29/2005
Old Jan 29, 2005 | 03:31 AM
b19coupe's Avatar
Default Re: very wierd bogging vtec problem | video and dyno graph inside (milano2kdc2)
How is your oil level? One possible cause.
Old Jan 29, 2005 | 03:43 AM
JCushing's Avatar
whats your vtec set at? also how come 5k is set at 0 fuel while all other areas are at least -3
Old Jan 29, 2005 | 08:07 AM
Eddiebx's Avatar
was that video shot at WOT? or part throttle?
Old Jan 29, 2005 | 11:02 AM
Default Re: very wierd bogging vtec problem | video and dyno graph inside (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">How is your oil level? One possible cause.</TD></TR></TABLE>
oil level is norm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing &raquo;</TD></TR><TR><TD CLASS="quote">whats your vtec set at? also how come 5k is set at 0 fuel while all other areas are at least -3</TD></TR></TABLE>
vtec is set at 5400 rpm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">was that video shot at WOT? or part throttle?</TD></TR></TABLE>
WOT, its even worse at part throttle
Old Jan 29, 2005 | 11:23 AM
importboi22's Avatar
check your oil pressure
what is your valve lash?
try a different ECU
switch vtec solinods (SP?)
make sure the wiring is nice and good to the vtec solinod and there is no shakey/exposed/bad connections from the ecu to the solinod
Old Jan 29, 2005 | 11:24 AM
iH8RICERZ's Avatar
dude...we'll try to trouble shoot it and go from there to see if it is in fact the program that needs to be fixed or what. Give me a call after you test out those other ecu's.
peas
Old Jan 29, 2005 | 02:33 PM
i changed the vtec x-over to 5600, it helped but when i shift red line from 1st to 2nd, it boggs a bit.
Old Jan 29, 2005 | 04:54 PM
V8SHME8's Avatar
Default Re: (milano2kdc2)
Mine did that when I had a failing ignition. I ended up cleaning the plugs, changing wires, cleaning terminals, and replacing the ignitor and my problem has not come back.
Old Jan 29, 2005 | 09:30 PM
Eddiebx's Avatar
one posibility is ur engaging vtec tooo soon for the cams you have. if there is a big jump between the vtec lobe and the primaries it can buck like that, especially at part throttle or low load.
Old Jan 29, 2005 | 10:13 PM
kamikaze158's Avatar
Default Re: (Eddiebx)
Run a full tuneup....Spark plugs, Spark plug wires,new oil,distributor cap and rotor, ignitor.Take out your vtec silenoid and clean it out .Check your settings in your vtec controller.
Old Jan 29, 2005 | 11:37 PM
DOHCtorTHRUST's Avatar
Default Re: (kamikaze158)
my bet is on the vtec crossover, my cousins b16a did just the same, once i hooked up the vafc and RAISED the cross over, problem was solve.
Modified by DOHCtorTHRUST at 8:18 PM 1/30/2005
Old Jan 30, 2005 | 07:13 AM
FerioVtec94's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by milano2kdc2 &raquo;</TD></TR><TR><TD CLASS="quote"> when the car is bogging, the car shakes hard as if i was tapping the gas.
i'd check your plugs and make sure the car isn't leaning out, i doubt that problem is bc of the vtec crossover
Old Jan 30, 2005 | 10:13 AM
civicgsr19's Avatar
Default Re: very wierd bogging vtec problem | video and dyno graph inside (FerioVtec94)
Has anyone checked the TPS voltage?
Old Jan 30, 2005 | 11:09 AM
99B16Si's Avatar
thats a lot of fuel pressure
Old Jan 30, 2005 | 04:24 PM
Default Re: (99B16Si)
i know what the problem is now. its the dumbest thing thats ever left me hanging on whats wrong with my car.
when i went on the dyno, the guy tuned it with my exhaust silencer off for most power.
the exhaust is so loud that i cant stand driving it on the street without the silencer on.
with the exhaust silencer off, the car runs like a champ, what a stupid solution
thanks for all the help guys
Old Jan 30, 2005 | 09:23 PM
iH8RICERZ's Avatar
LOL...you freakin swear thats all it was???! hahahhahahah, WEAK SAUCE man... anyways, good job finding out
Old Mar 4, 2005 | 03:02 PM
Stripped Si's Avatar
Default Re: (iH8RICERZ)
It's a sign...leave the damn silencer off! hehe
Old Mar 6, 2005 | 08:36 PM
colinproctor's Avatar
Default Re: (Stripped Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stripped Si &raquo;</TD></TR><TR><TD CLASS="quote">It's a sign...leave the damn silencer off! hehe </TD></TR></TABLE>
more of a sign to not have an exhaust that needs a silencer.
93turbo16
24
Jan 9, 2006 11:20 AM
matix
Aug 31, 2004 07:59 AM
6ghatch
30
May 31, 2004 08:52 AM
RedTeg95
Apr 25, 2002 07:45 PM
Mr. Softee
Feb 10, 2002 09:11 AM
