swapping a 1991 HF motor to 1994 CX motor?????NEED HELP!!!!
Old Jan 28, 2005 | 11:31 PM
BrothaSit's Avatar
Default swapping a 1991 HF motor to 1994 CX motor?????NEED HELP!!!!
aights im doing a swap for a friend...its a 1991 crx HF...im swapping it with a 1994 cx motor...the intake manifold matches perfectly...the only thing im stuck on is....1) the coolant sensor which on the crx is above the oil filter while the CX motor is mounted on the thermostat housing.....2) the driver side motor mount doesnt look the same but you think will it still work? 3)are the flywheel and clutch the same? oh yea and the other thing is the motor was sitting in my garage for 4 months and for some reason the spark plug wont come out....i remember i always use the anti sieze on all my spark plugs...is there a way to remove them without stripping the threads?
druidesque
12
Dec 1, 2009 10:46 AM
VRD^don
17
Feb 26, 2004 10:27 AM
DC2 12
Aug 10, 2002 12:02 PM
hmonglonertim
Jul 30, 2002 01:15 PM
