no heat, hot engine
Old Jan 28, 2005 | 10:08 PM
Stevorh's Avatar
Default no heat, hot engine
Today i was driving and for the first time ever, my temperature needle shot from below cold, to 3/4 of the way to hot within 3 seconds. My car never runs this hot, and so i turn on the heater to get some heat because it's cold outside, and all it's blowing is cold air. How can my engine say that it's running hot, and i still have no heat? It's never done this before, can someone help?
Old Jan 28, 2005 | 10:59 PM
GOLDBERG's Avatar
Default Re: no heat, hot engine (Stevorh)
temp sensor maybe?
Old Jan 29, 2005 | 12:03 AM
Stevorh's Avatar
Default Re: no heat, hot engine (GOLDBERG)
would that make my heater not work?
Old Jan 29, 2005 | 08:46 AM
Chillinit's Avatar
heater core
Old Jan 29, 2005 | 09:24 AM
k24a4kid's Avatar
I'm a Jackass
Default Re: no heat, hot engine (Chillinit)
termastat went bad
Old Jan 29, 2005 | 09:39 AM
Stevorh's Avatar
Default Re: no heat, hot engine (turbofienD 04)
i changed the thermostat
Old Jan 29, 2005 | 10:00 AM
k24a4kid's Avatar
I'm a Jackass
when you change it?
Old Jan 29, 2005 | 10:33 AM
Jamez's Avatar
If your heater core is full of nothing then it won't matter how hot your engine is, you won't be getting any heat. It happened to me this winter in like -20C weather. (Check your coolant level, start the car without the cap on to let the air out. Warning, do not open the cap when the engine is hot).
If your waterpump is broken or the system is clogged then your coolant will sit still and won't go anywhere near the radiator to get cooled...
Old Jan 29, 2005 | 10:17 PM
Stevorh's Avatar
Default Re: no heat, hot engine (Jamez)
i just changed the thermostat, so that's not the problem
Old Jan 29, 2005 | 11:11 PM
Jamez's Avatar
I didn't mention anything about the thermostat...
However, the fact that you changed it could cause the problem your having if you did not bleed the system properly afterwards. You need to run the car for a while with full heat on the climate control and the radiator cap on the first click (or no cap at all, its just messy though) to let the air out. Then unscrew the bleeder screw, fill the rad until straight coolant comes out the bleeder screw, tighten it back and put the radiator cap back on.
Like I said, if your heater core is full of air then its not going to let off much heat, nomatter how hot your engine is.
Old Jan 29, 2005 | 11:30 PM
DOHCtorTHRUST's Avatar
you prolly have a air pocket or coolant has leaked somewhere and the cause of that skyrocketing gauge was because of no coolant in the system.
thats my theory, hope that helps
Old Jan 30, 2005 | 05:55 AM
NJIN BUILDR's Avatar
Check the strength of the coolant.If its to week the coolant will turn slushy and the pump won't push it.Some times it will freeze in the heater core and not circulate.You can just drain a gallon out of the radiator and refill with straight antifreeze.
Glenn
Old Jan 30, 2005 | 06:49 AM
Pondus's Avatar
Default Re: no heat, hot engine (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">Check the strength of the coolant.If its to week the coolant will turn slushy and the pump won't push it.Some times it will freeze in the heater core and not circulate.You can just drain a gallon out of the radiator and refill with straight antifreeze.
Glenn</TD></TR></TABLE>
This is good advice, do as he says, i have experienced the same on a old car of mine, and it turned out that the coolant was good for -7 degrees C, and it had been -15 outside for a couple of days
Old Feb 2, 2005 | 04:06 PM
Stevorh's Avatar
Thanks a lot for the advice. I think the problem is the water pump. I'll change it and let you know if that was the problem
jackhis
Jun 18, 2022 10:26 PM
KidZr0
19
Sep 1, 2011 01:28 PM
jdm36
29
Dec 17, 2010 06:59 PM
drmix
Dec 16, 2008 01:01 PM
s1ngle
Dec 12, 2005 05:26 AM
