Power steering question.
Old Jan 28, 2005 | 09:19 PM
rasinhell's Avatar
Default Power steering question.
Hey guys I remember there was a special technqiue people did with looping a tube on the power steering rack. I can't seem to find the thread, does anyone know of the process?
Old Jan 28, 2005 | 09:25 PM
chameleon's Avatar
Default Re: Power steering question. (Special-Ed)
yeah you basically find the two ports that have the hardlines that lead to the pump and the other one that leads to the canister, you find the fittings at the hardware store where basically you will make a T connection and the end of it goes up to any little reservoir you want to use where it will let air flow throught the system but you can keep it lubricated from the reservoir.
very ruff explination.
Old Jan 28, 2005 | 09:26 PM
rasinhell's Avatar
Default Re: Power steering question. (chameleon)
Would it be bad if this guy has been running the car w/o P/S for a while and all the fluid is probably sucked out and dry? Would there be some way to hydrate it withs ome P/S fluid and then loop the lines like your suggesting? I'm assuming it needs some type of fluid in there for this trick to work right?
Old Jan 28, 2005 | 10:05 PM
Street Ghost's Avatar
mine is looped with a breather reservior. i love the feeling of it.
look up user: padawan
Old Jan 28, 2005 | 10:11 PM
rasinhell's Avatar
Default Re: Power steering question. (_Edge.ONE)
hey i foudn the thread. Now my main question is how am I going to re-hydrate the system with power steering fluidd if it's been disconnected for quite some time now?
thanks.
Old Jan 28, 2005 | 11:42 PM
what do u mean disconnected? u took off the belt or you completely removed everything and just left the holes on the rack exposed?
Old Jan 29, 2005 | 09:32 AM
rasinhell's Avatar
No, he took the pump off, and then the long tube that connects to the pump I think, he removed that but it was just hanging around in the engine bay. so pretty much yeah, he just disconnected it and left the hoses exposed
oneheadlight
Nov 22, 2015 05:31 AM
Mishako129
May 11, 2013 01:06 AM
tt3
Oct 6, 2011 04:43 PM
old_school_dohcvtec
Jan 18, 2006 03:23 AM
peel17
Jan 20, 2005 09:14 AM
