Brake booster w/ master cylinder, options
ive read up:
https://honda-tech.com/zerothread?id=152884
and
https://honda-tech.com/zerothread?id=1096939
just have a quick q. what brake booster would work well [most compatible] with the 96+ ex ? i know the ITR bolts up directly and its a 1".
what about an LS or GSR ? those, are 15/16th ? would you be able to use the stock BB and use a LS or GSR MC ? thanks
and
wow this is like the 242825625 post on brake boosters this week.
for 96+ civics your best upgrade is to a 98+ ITR/GSR which is 1" the is the BEST bolt up no modification needed upgrade, second best is the 7/8th from a 00 SI.
i have both for sale if anyone is interested. itr one is on ebay endind in 45min!
http://cgi.ebay.com/ws/eBayISA...SE:IT
u dont want that, 96+ are lucky cuz the itr mc bolts up and u dont have to flare any lines or do anything im talking about straight bolt up plug and play and you get the biggest mc possible.
15/16ths is a good upgrade for 92-95s because its the biggest you can get the will plug in without any line bending or anything but even then i say throw a 1" in that bitch and use custom lines. well worth it
no mc should be disconnected with this matching BB, they should always go together, they are interchangle if they have the same bolt angle but you most likely will decrease its power by not using the correct 1" BB.
SiRkid
Jan 10, 2004 09:49 AM
jr_istheman
Jun 23, 2003 05:17 AM
