civic eg b18c cat converter?
i am doing a 95 b18c1 swap in my eg. i was wondering what cat should i get. i don't wanna go to the muffler shop to get one custumed. that will be my last resort. will a 98 gsr cat work? i heard a ls cat will fit? what yr. ls cat will fit? or it doesn't matter. what radiator hose do i use? the del sol dohc hose? will integra hoses work?
Modified by shyboi4u at 6:03 PM 1/29/2005
when i put a 94 b18c1 into my car, i also used the GSR cat as well and it bolted right up and it made wiring of the o2 sensor very easy. i think obd2 cats have to 02 bungs going into them, but i'm not totally sure. or atleast i've seen them that way.
koo, thanks...i'm thinking bout getting a random tech. high flow cat. what would be better to get? what radiator hoses did you use?
Modified by shyboi4u at 6:04 PM 1/29/2005
Use integra radiator hoses. I believe that the radiator hoses are bigger for b-series engines than the civics so the integra's hoses would work best.
HTH
HTH
crexer
Jul 9, 2006 09:56 PM
Kyles ej1
19
Sep 30, 2005 12:01 PM
shyboi4u
Jan 28, 2005 04:27 PM
