What fuse do I pull to get the check engine light to go away.
I pulled the IACV electical connector off and adjusted my idle.....however, i cannot figure out what fuse to pull to clear the ECU code.....I know I can just disconnect the battery however, I want to know what fuse I can pull to get the same result.
There are two that I pull. The ECU and the ECU Backup. They are labeled on the fuse box under the hood on the passenger side of the car by the battery...
Jason
Jason
phoenix_iii
Mar 14, 2009 05:01 PM
9civic8
Apr 2, 2004 08:51 AM
