injectors for n/a setup? worth buying?
Old Jan 28, 2005 | 02:48 PM
B18cHatch06's Avatar
Default injectors for n/a setup? worth buying?
would it be worth it to buy new injectors for my n/a poor mans r setup?? what size do they come with stock in my obd-1 b16 head?
i plan to get blox s2 cams with ctr pistons n some others tuned with hondata so any opinions would help!!!
Old Jan 28, 2005 | 03:20 PM
1999all_motoR_teg's Avatar
Default Re: injectors for n/a setup? worth buying? (B18cHatch06)
All B series motors come with 240cc saturated injectors.
Unless you see on a dyno that you are running max duty cycle on the stock ones I see no need to go bigger.
I was gonna go bigger as well. Decided as soon as my car comes out of storage I'll go for a dyno tune and see where they are at.
Old Jan 28, 2005 | 08:17 PM
MugenRacerX's Avatar
Arent odb1/2 injectors peak and hold?odb0 are saturated and require that resistor box.
If your building an engine package properly then you would already have injectors in your target range,Theres some calculators with-in a search that tell you what size injector for your engine.. displacent, compression whats size cams yatta yatta.
Old Jan 28, 2005 | 09:09 PM
Kapman38's Avatar
I have all motor ITR. Went with Prelude 295CC injectors, cheaper then aftermarket. Will keep duty cycle down and work more effectively. obd2 can be rewired for obd-1...just different clips..
Old Jan 29, 2005 | 12:12 AM
rice killer's Avatar
Default Re: injectors for n/a setup? worth buying? (Kapman38)
cough cough what about the jdm b20...(1989 honda prelude si's)??
Old Jan 29, 2005 | 07:56 AM
athoughts's Avatar
Default Re: injectors for n/a setup? worth buying? (rice killer)
ive got a b16a2 and was plannin on getting injectors as well but heard they are not needed with a n/a setup, unles your boosting or runnin nos its not going to be much better
- p&p head
- HKS cat back
- AEM cia
- stage 2 cams
- AEM cam gears/pully
- AEM fuel rail
- 4-1 header
- bullfrog TB
- aebs intake manifold
Old Jan 29, 2005 | 11:05 AM
allmotorgsrekk's Avatar
prelude injectors are a good upgrade for 1.8 na motor
DC2fab
Apr 9, 2010 09:31 PM
01_ITR
Apr 8, 2009 03:29 AM
Baodalazi
Nov 1, 2006 11:22 AM
alexb16hb
May 13, 2006 10:18 AM
eag36
Apr 1, 2005 01:18 PM
