car starts then dies!
Old Jan 28, 2005 | 12:43 PM
boostedcivic25's Avatar
Default car starts then dies!
when i turn the ignition key the starter turns over and starts and as soon as i let go of the key the car dies. if i hold the key in the start position it will keep running. i replaced the main relay and it did not work (waste of $60). the guy up at honda said that it might be the ignition switch. let me know asap b/c im stuck w/o a car.
thanks alot.
-Seth-
Old Jan 28, 2005 | 12:56 PM
96-EJ6 B18C's Avatar
Default Re: car starts then dies! (boostedcivic25)
Double check the grounds.
Old Jan 28, 2005 | 01:15 PM
FalkenSiR's Avatar
Default Re: car starts then dies! (96-EJ6 B18C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivic25 &raquo;</TD></TR><TR><TD CLASS="quote"> it might be the ignition switch.</TD></TR></TABLE>
second that.
Old Jan 28, 2005 | 01:16 PM
JohnnieChimpo's Avatar
You need to make sure your distibutor is getting power while the switch is in the on position. I think it is a Black w/ yellow wire. Use an online Helms or buy one to do a check on it. If it isn't getting 12volts you probably need a switch.
Old Jan 28, 2005 | 02:01 PM
Default Re: car starts then dies! (JohnnieChimpo)
thanks guys ill check all that and get back to you with the results.
Old Jan 28, 2005 | 03:39 PM
thanks guys got it fixed. it ended up being the ignition switch wire harness that needed to be replaced.
Old Jan 28, 2005 | 03:53 PM
vtecn8ive's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivic25 &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys got it fixed. it ended up being the ignition switch wire harness that needed to be replaced.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivic25 &raquo;</TD></TR><TR><TD CLASS="quote">might be the ignition switch. </TD></TR></TABLE>
I don't think its the ignition wires trying switching cars it should work then. j/k good to hear H-t comes through for once
Old Jan 29, 2005 | 02:15 AM
VivaLaYessica's Avatar
Default Re: car starts then dies! (vtecn8ive)
glad you got it fixed
NOSblast
Nov 12, 2012 10:17 AM
JONESER
Aug 21, 2008 07:44 PM
b00sted4dr
Jul 31, 2006 05:14 PM
b00sted4dr
Jul 31, 2006 05:00 PM
HT Chaplain
Feb 21, 2005 03:55 AM
