car starts then dies!
Old Jan 28, 2005 | 12:42 PM
boostedcivic25's Avatar
Default car starts then dies!
when i turn the ignition key the starter turns over and starts and as soon as i let go of the key the car dies. if i hold the key in the start position it will keep running. i replaced the main relay and it did not work (waste of $60). the guy up at honda said that it might be the ignition switch. let me know asap b/c im stuck w/o a car.
thanks alot.
-Seth-
Old Jan 28, 2005 | 01:37 PM
JimBlake's Avatar
Default Re: car starts then dies! (boostedcivic25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivic25 &raquo;</TD></TR><TR><TD CLASS="quote">... it might be the ignition switch.</TD></TR></TABLE>The fact that it'll run when you hold the key in a funny position makes this a pretty good bet.
Old Jan 28, 2005 | 01:59 PM
Chiovnidca's Avatar
Default Re: car starts then dies! (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">The fact that it'll run when you hold the key in a funny position makes this a pretty good bet.</TD></TR></TABLE>
Some thing are pretty obvious, huh?
Old Jan 28, 2005 | 03:40 PM
Default Re: car starts then dies! (Chiovnidca)
got'er done. ended up being the ignition switch wire harness.
Easyslider01
15
Dec 30, 2006 11:57 AM
H22CL
Jul 31, 2005 05:41 PM
PGT Driver
Apr 29, 2005 11:24 AM
drumking15
Jul 19, 2004 10:53 PM
wizzards581
12
Dec 11, 2003 06:25 PM
