blown piston ring worth fixing?
i have a 91 crx si and i got it with the stock engine, i was just wondering if a blown piston ring(the problem that i have been told) is worth fixing. All i know is that there is black smoke when running, and it does seem to run ok for the exception of the black smoke coming out of the exhaust. Should i fix it or just wait for a swap?
Perfrom a compression and leakdown test. Make sure it is a blown piston ring. Usually with blow rings you will burn oil whichwill produce white/blue smoke. Black smoke usually indicates the engine is running very rich.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shawn_crx »</TD></TR><TR><TD CLASS="quote">swap
unless you fix it yourself and on a tight budget</TD></TR></TABLE>
most definitely. cost more than your car is worth if you cant do it yourself.
swap is most definitely a good choice unless you are on a tight budget.
oh and also do you think it would be ok to drive for a while untill i swap it? I mean it seems to run fine... but i dont want to find myself breaking down someplace like i have with other far less reliabe cars...(PONTIACS SUCK!)
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kleenCRX »</TD></TR><TR><TD CLASS="quote">oh and also do you think it would be ok to drive for a while untill i swap it? I mean it seems to run fine... but i dont want to find myself breaking down someplace like i have with other far less reliabe cars...(PONTIACS SUCK!)</TD></TR></TABLE>
i drove on an 200K miles engine that consumed around 1 quart of oil every week.
it is possible, and i would repair the engine, A6 are very potential engines.
stan
stan
haven't u ever seen that video on this site (somewhere; don't feel like searching for it.) some pasty white boys from florida drain all the fluids (coolant for sure but i think motor oil too!!!) and let it run bouncing off the rev limiter with a brick on the gas pedal in neutral....i wanna say that the thing stayed alive for like 20 minutes b4 sparks start shooting out the tailpipe and it seized up. i don't think you'll have a problem with it just plain breaking down on u if it's just rings....but as someone else mentioned, i'd do a compression test on it first cuz black smoke doesn't mean a bad ring...might just be really nasty old o2 sensor or some sensor dealing with fuel management.
GSR_hatch936
21
Apr 28, 2007 11:10 PM
jadugartir
Aug 1, 2004 07:05 AM
