JE pistons? What CR ratios are out there?
Old Jan 14, 2002 | 08:03 AM
austrian type-R's Avatar
Default JE pistons? What CR ratios are out there?
I wonder what the different compression ratio specs for the JE pistons are.
I know there is 9:0 and 11.5:1 cr
I can use JE pistons for the GSR which gives ma about 10.5:1 cr, cause of the bigger combustion camber of the ITR-head.
What about using non-vtec B18A Integra pistons 10.5:1; 9.2:1; 8.5:1. Are they okay for my head and valve clearence and what cr ratio would they give me? What else can I chose?
Honda pistons: 11.1:1; 10.6:1; 10.1:1 (GSR.JDM); ~9.6:1 (GSR-JDM)
.....but Honda pistons are´nt so strong than JE, corect? Are the JE pistons for the B18A engines as strong as for the B18C ones?
Thanks!
Old Jan 14, 2002 | 08:44 AM
sgT's Avatar
sgT
Default Re: JE pistons? What CR ratios are out there? (austrian ITR)
11.5 b18c pistons will give you just over 11:1.
JE can custom make any CR you want. just takes a little longer.
B18A pistons would work as well. shouldnt be any difference in quality.
idewson
Dec 7, 2005 03:50 PM
GDM Z28
Jul 28, 2004 02:06 PM
blazin
Jul 11, 2003 06:11 AM
austrian type-R
Jan 14, 2002 05:45 PM
