TWM ITB's and throttle cable
I just picked up a set of TWM ITB's and I am trying to do some reasearch before the install. Does anyone know what throttle cable to use for a B16B in an EK with the ITB's? Need help
Thanks for the help
, I figured that but I just want it to be a clean install, not having cables and lines rinning all over the place.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chameleon »</TD></TR><TR><TD CLASS="quote">whatever reaches ... whatever you have should be the right length if the stock ones are the ones that are supp to be used.</TD></TR></TABLE>
um no since he already has a swap I doubt he's running anywhere near this length
check the all motor forum or apperance this guy is a Honda-Tech member
