injectors for itb's
Old Jan 28, 2005 | 10:19 AM
hybridnorth's Avatar
Default injectors for itb's
Hey
i picked up a set of cbr 954 tbs , and look at the injectors, which ones are you guys using? the cbr ones or civic? did you re-jet the cbr ones? or change the clips and install the civic ones? also i saw a thread on here, a guy is using the cbr tb's and the cbr fuel rail, wont a aftermarket fuel rail work?
Old Jan 28, 2005 | 10:34 AM
RCautoworks's Avatar
Default Re: injectors for itb's (hybridnorth)
Yes an aftermarket fuel rail should work, and I would talk to the member gutted. I think he was using h22 injectors because other injectors would not fit.
Old Jan 28, 2005 | 02:02 PM
Default Re: injectors for itb's (90blackcrx)
cool thanks, ill im him
anyone else know?
Old Jan 28, 2005 | 06:17 PM
rice4life's Avatar
if you put the injectors on the itbs location, then you would need to use the fuel rail that came with the itbs and you can't use any injectors larger than the ones from the car. so you that means you can't use RC injectors. if you put the injectors on the oem flange stock location , then you can use the oem fuel rail or aftermarket fuel rail. the advantage of putting the injectors on the itbs location is better fuel atomization.
Old Jan 28, 2005 | 06:41 PM
Default Re: injectors for itb's (rice4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rice4life &raquo;</TD></TR><TR><TD CLASS="quote">if you put the injectors on the itbs location, then you would need to use the fuel rail that came with the itbs</TD></TR></TABLE>
Thats not true. I have seen people use the itb fuel injector location but then use a stock fuel rail.
Old Jan 28, 2005 | 11:15 PM
rice4life's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Thats not true. I have seen people use the itb fuel injector location but then use a stock fuel rail.</TD></TR></TABLE>
i was taking about cbr itbs, if you use gsx itbs and get the runners to line up straight then you can use the stock fuel rail. cbr itbs won't line up straight, so you have to use the itb fuel rail.
Old Jan 28, 2005 | 11:24 PM
i was taking about cbr itbs, if you use gsx itbs and get the runners to line up straight then you can use the stock fuel rail. cbr itbs won't line up straight, so you have to use the itb fuel rail. </TD></TR></TABLE>
Oh ok, makes sense. But will the cbr fuel rail allow enough fuel to pass threw ?
Old Jan 29, 2005 | 07:10 AM
rice4life's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Oh ok, makes sense. But will the cbr fuel rail allow enough fuel to pass threw ?</TD></TR></TABLE>
cbr fuel rail should be fine for NA application unless you are planning on making 250+ whp, you really only need high flow fuel rail in force induction.
Old Jan 29, 2005 | 08:48 AM
would you happen to know the size of the 954 injectors? can i get them rejetted?
Old Jan 29, 2005 | 10:46 AM
rice4life's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridnorth &raquo;</TD></TR><TR><TD CLASS="quote">would you happen to know the size of the 954 injectors? can i get them rejetted?</TD></TR></TABLE>
i've heard people saying they were 240cc but no one has confirm it. some one was going to send them to RC to get them flow tested but they never got back to me with the results. i'm planning on trying them but haven't got the time to yet.
Old Jan 29, 2005 | 11:10 AM
i read somewhere someone used h22 injectors, are they different from other size cc's from the stock civic ones?
the cbr injectors are alot smaller in diameter i've noticed, hopefully they will be good enough, my setup is approx 12.2:1
i might have to do some serious dremeling to make the other ones fit if need be
Old Jan 29, 2005 | 07:10 PM
rice4life's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridnorth &raquo;</TD></TR><TR><TD CLASS="quote">i read somewhere someone used h22 injectors, are they different from other size cc's from the stock civic ones?
i might have to do some serious dremeling to make the other ones fit if need be</TD></TR></TABLE>
h22 injectors are physcially the same size as all other honda injectors for automobile, so they will fit on the itbs location. larger injectors will hit the idle control bar, you can probably fine a way to rig it though.
Old Jan 30, 2005 | 08:22 PM
machine4321's Avatar
i have some 2900 cc lude injectors ...there identical out side to the gsxr injectors..i mean exactly ..kinda cool ..i just dont want to take ou tmy resistor box..
they are for sale
airwalk07143
Dec 30, 2008 05:56 AM
85
Honda Motorcycles
Feb 13, 2007 08:30 AM
NitrousB.I.G.
Jul 8, 2006 12:34 PM
Que_Lude
Dec 24, 2002 06:34 AM
MartGSR
Jul 21, 2002 04:50 PM
