cam gear and distributer question
Old Jan 28, 2005 | 08:54 AM
crxhf_gsr_blades's Avatar
Default cam gear and distributer question
im doing a mini me on my 90 hf. the head i have doesnt have a cam gear, will my hf cam gear work? also will my distributer bolt up. thanks for the help guys. oh yeah its a y8 head.
Old Jan 28, 2005 | 09:30 AM
mrspeaker's Avatar
Default Re: cam gear and distributer question (crxhf_gsr_blades)
The hf/si distributor fits..The dx fits to but will require you to run dpfi..
Im not sure about the cam gear though?
Old Jan 28, 2005 | 10:20 AM
mellon's Avatar
Default Re: cam gear and distributer question (mrspeaker)
I'm fairly sure the cam gear won't work. I would be very suprised if the 1.5l cam gear was the same as the y8 1.6l.
Old Jan 28, 2005 | 10:30 AM
dr_latino999's Avatar
Woah, are you doing a mini-me project on the STOCK HF block, if so, it won't work. Back to your question though, you need a Y8 cam gear as they were different (alignment marks relative to the cam) compared to the SOHC cam gears prior.
Old Jan 28, 2005 | 10:33 AM
mrspeaker's Avatar
Default Re: cam gear and distributer question (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">Woah, are you doing a mini-me project on the STOCK HF block, if so, it won't work.</TD></TR></TABLE>
Why wont it work..?
I heard something about its because the hf is 8 valve and the valve reliefs?
I never did understand though..
Old Jan 28, 2005 | 10:42 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrspeaker &raquo;</TD></TR><TR><TD CLASS="quote">Why wont it work..?
I never did understand though..</TD></TR></TABLE>
On your standard piston (16 valve motor) you have four reliefs as shown here -
On your 8-Valve motor you have two reliefs, one for intake and one for exhasut and they are in the center of the piston, not on the outside corners. You would end up then with your valves potentially coming into contact with your piston more often then not. If he wants to maintain a HF block, he will need to pick up a set of D15B2 or any 1.5L 16 valve pistons.
Old Jan 28, 2005 | 10:46 AM
mrspeaker's Avatar
Thanks for explaining..
Old Jan 28, 2005 | 12:30 PM
well i thought that was just on b20/vtec, well, your i need different pistons and cam gear from a y8 and d15b2 pistons, this is weird ive never heard this before(about the pistons) well thanks guys
gramentz
Aug 31, 2013 09:44 AM
xmd
Dec 13, 2003 03:03 AM
slvrcivic97
Jul 28, 2003 01:32 PM
