Question on HID, can i use A6 or S2000 projectors with D2r bulbs ?
Old Jan 28, 2005 | 07:06 AM
MikeTV
Guest
Posts: n/a
Default Question on HID, can i use A6 or S2000 projectors with D2r bulbs ?
I was gonna buy HIDs from an IS300, but they include d2r bulbs because the is300s use reflectors, not projectors.........Can i still use these bulbs with projectors from a different car, or will the d2r casing not fit ??
Old Jan 28, 2005 | 07:10 AM
Alexander's Avatar
Default Re: Question on HID, can i use A6 or S2000 projectors with D2r bulbs ? (Eclipse spanker)
to my understanding, if you get A6 or S2000 or e55 projectors/lenses (most commonly used for integra retrofits) you are going to have to acquire D2S bulbs as well. You can't use D2R bulbs in the previously stated OEM housings, rendering your existing "HID Kit" useless, that is except for the ballasts.
A6/s2000/e55 projectors + new 4100k D2S bulbs + new or existing ballasts (doesn't matter) =
Old Jan 28, 2005 | 07:12 AM
MikeTV
Guest
Posts: n/a
Default Re: Question on HID, can i use A6 or S2000 projectors with D2r bulbs ? (Alexander)
oh, so I can use the ballasts and ignitors that I have now, with new d2s bulbs ? How much do the bulbs go for ?
Old Jan 28, 2005 | 07:13 AM
nek0's Avatar
Stock HID bulbs are pretty cheap nowadays, check on eBay, I think you could get a pair for $100 or so. D2S doesn't have any kind of shield coating on the bulb
Old Jan 28, 2005 | 07:15 AM
Alexander's Avatar
Also, for your reference:
HID retrofit club
What projectors fit in an Integra headlight for HID Retro?
E46 Projectors-->'00 Civic*How To*Updated often*Attn: Hondazvic *12 Pics*
Skafia's 1998 Integra Type R OEM HID Retrofit
HID Planet
HID Planet Forums
Old Jan 28, 2005 | 08:49 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
HID Planet sells Philips 4100K D2S bulbs for $75/pair brand new.
A D2R can be converted to D2S by removing the black strip around the globe, but I personally wouldn't want a "ghetto'd" D2S bulb.
Both will work with the same ballast, because they both have a D2 base.
Old Jan 28, 2005 | 09:00 AM
MikeTV
Guest
Posts: n/a
Default Re: (PatrickGSR94)
ok sweet. thanks for your help guys
BKKloppenborg
May 13, 2008 05:36 AM
bluesaint
Northern California (Sales)
Jul 25, 2006 07:48 AM
Kelvin96GSR
May 19, 2004 01:34 AM
NightHawkC5
Honda S2000
Jan 25, 2004 11:15 AM
