WTF is this nasty smell coming from my air vents?????
Old Jan 28, 2005 | 05:27 AM
EM1_GIL's Avatar
Default WTF is this nasty smell coming from my air vents?????
its winter people usually use heaters well not me. this smell from my vents that smells like dirty gym clothes that have been washed for weeks.
it doesn't always smell say i drive for an hour that **** will just smell half the time and its is not constant i goes and comes. so for now to closed the 2 vents i could and put it to vent to the floor. this is extremely embarrassing and any help would be appreciated
thanks ahead and i dont see a need to flame
Old Jan 28, 2005 | 06:08 AM
JDM EJ1 95's Avatar
probably the heat and moisture causing mold in the vents? run some lysol through the vents
Old Jan 28, 2005 | 06:16 AM
ek9800's Avatar
Default Re: (JDM EJ1 95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM EJ1 95 &raquo;</TD></TR><TR><TD CLASS="quote">probably the heat and moisture causing mold in the vents? run some lysol through the vents</TD></TR></TABLE>
agreed. it's mostly like mold.
Old Jan 28, 2005 | 07:00 AM
yaya's Avatar
Default Re: WTF is this nasty smell coming from my air vents????? (EM1_GIL)
you have a dead bird in your cowl
Old Jan 28, 2005 | 07:02 AM
Ricey McRicerton's Avatar
Default Re: (ek9800)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9800 &raquo;</TD></TR><TR><TD CLASS="quote">
agreed. it's mostly like mold.</TD></TR></TABLE>
Most likely. If you smoke in the car, that can cause that nasty smell too.
Old Jan 28, 2005 | 07:03 AM
mwieczorek43's Avatar
Default Re: WTF is this nasty smell coming from my air vents????? (yaya)
Do you have any ememies??
My ex-girlfriend poured milk in the vents above my hood... it got into the heating/cooling duct-work. Smelled like rotten-feet forever!! Eventually ended-up replacing all the duct-work.. Hope that isnt what happened to you.
Old Jan 28, 2005 | 07:05 AM
K I O K E N's Avatar
Default Re: WTF is this nasty smell coming from my air vents????? (mwieczorek43)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mwieczorek43 &raquo;</TD></TR><TR><TD CLASS="quote">Do you have any ememies??
My ex-girlfriend poured milk in the vents above my hood... it got into the heating/cooling duct-work. Smelled like rotten-feet forever!! Eventually ended-up replacing all the duct-work.. Hope that isnt what happened to you.</TD></TR></TABLE>
Damn...
Old Jan 28, 2005 | 07:40 AM
dunkd's Avatar
does it smell like coolant at all? possibly could be a leaky heatercore
Old Jan 28, 2005 | 09:48 AM
EM1_GIL's Avatar
Default Re: (dunkd)
-i dont smoke
-my ex-girls boy may have but i always watch my car garage kept
-coolant smell reminds me of dirty koch this smells like sweat or something
i will definitely try the Lysol tho thanks for the feedback
Old Jan 28, 2005 | 09:56 AM
89 EF Si's Avatar
m89 civic sat in my dad garage for year and i was driving it and turned the heat on and all this **** came out........mice lived in hatch.....eewww
Old Jan 28, 2005 | 10:35 AM
130R's Avatar
previous owner probably hid weed in there
Old Jan 28, 2005 | 10:43 AM
cvccjdm's Avatar
if u run ur a/c during the summer time and not properly blow out the moisture it would cause that (mildew built up) smell. i make it a habit to run the fan on with out the a/c about 1/4 of a mile before i get there.
that's a mold build up on ur vents.
Old Jan 28, 2005 | 10:44 AM
Simple SOHC's Avatar
So do you just take a bottle of lysol and pour it down the vents where the wiper blades are? How much should you use?
Old Jan 28, 2005 | 10:46 AM
POE's Avatar
POE
Default Re: WTF is this nasty smell coming from my air vents????? (carbing'ed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carbing’ed &raquo;</TD></TR><TR><TD CLASS="quote">previous owner probably hid weed in there</TD></TR></TABLE>
ewww, Im not smoking anything that smells like sweat and ***
Old Jan 28, 2005 | 10:48 AM
WyteNyteGSR's Avatar
My friends tells me my heat smells like a wet dog.....but as long as im warm...i could give a **** less about me coming out everytime reaking like "wet dog"..its better than hypothermia. ..but yea...if somebody knows something they did, that worked...i just might try it out....
Old Jan 28, 2005 | 09:51 PM
chameleon's Avatar
Default Re: WTF is this nasty smell coming from my air vents????? (WyteNyteGSR)
if you remove the glove box you will see the blower, on that foam **** just spray tons of cleaner, fabreeze, whatever and it should help out. im bout to do it on mines. ex owner was a smoker.. **** never again!!
Old Jan 28, 2005 | 11:08 PM
b 1 6 a 2's Avatar
Default Re: WTF is this nasty smell coming from my air vents????? (chameleon)
Funny you mention that. I did that to mine yesterday. I sprayed some on the mesh part of the blower and sprayed a little with the fan on without the thingy closed so it can carry the fabreeze as far up the air ducts. I need to spray more to get the whole air ducts fresh.
Old Jan 28, 2005 | 11:10 PM
drevinder's Avatar
damm i though i was the only one with the stinky air problem...i guess i was to embarrassed to post it....
Old Jan 28, 2005 | 11:13 PM
pinky_owned_j00's Avatar
Default Re: WTF is this nasty smell coming from my air vents????? (drevinder)
fabreeze should do the trick, good luck
Old Jan 29, 2005 | 02:55 AM
Outrun's Avatar
Default Re: WTF is this nasty smell coming from my air vents????? (pinky_owned_j00)
After you get the smell out, keep the fan on, even at the lowest setting. This keeps air moving and minimizes the settling of particles.
My vents have never smelled bad.
Old Jan 29, 2005 | 05:05 AM
qat727's Avatar
Luckly I don't have this problem with my Si, but I did have it with my Saturn SC2. Apparently the car was a Florida flood victim, and the air smelled worse than a wet dog that had been dead for a few weeks. I turned the air on full tilt to fresh air, then sprayed fabreeze into the air intake for the heater. I emptied a quarter bottle of the stuff spraying it in there. After it kind of stopped smelling, I switched it over to recirculating and left it going for a while. It took the smell away for a few weeks, and when it came back, it was noticibly less bad. After a few more repeats of this treatment, the stink was gone. I would be wary of putting lysol in my air ducts, but to each his own. In my experience, lysol permanently scents any plastic it comes in contact with. If you like the smell of lysol, go for it. I know I don't, and the febreeze worked for me. As for what it is.... I really never figured it out for sure. My best guess was that the water got in, collected somewhere in the bowels of the system, mildewed, and that was the stink..... it partially going away after it had been on for a while seemed to make sense, as it would blow most of the stink out. Good luck on it.
Old Jan 29, 2005 | 07:42 AM
EM1_GIL's Avatar
Default Re: WTF is this nasty smell coming from my air vents????? (qat727)
thanks guys i going to buy some frebreeze and lysol and try it thanks again.
Andrew240z
31
Nov 18, 2005 04:36 AM
mattdenali
12
Jun 17, 2005 03:57 AM
john d
Apr 17, 2005 03:07 PM
BrockGrimes
13
Jan 6, 2004 12:34 PM
Witty
19
Aug 11, 2003 07:16 AM
