purge setup???
Old Jan 27, 2005 | 06:10 PM
fullblown's Avatar
Default purge setup???
I was wondering, whats a good way of setting up a purge?? how do you guys block the ends of the pipes? do you guys make a valve that sits next to the work station so u can control the gas?? thanks guys
Old Jan 28, 2005 | 04:09 AM
fabnewb's Avatar
Default Re: purge setup??? (fullblown)
what i do is i use masking tap to cover both ends. put the purge line in one side, then poke a hole in the other side. i use a sperate bottle, with a reg on the bottle set to x cfm, then i have a valve inline is mounted to my work table so i can shut the purge off without having to get up and close the large valve. hose i use is rated to 450psi, so its not gonna bust hope this helps. i'll try to get a pic up
VTECth1s
Welding / Fabrication
16
Jul 28, 2008 03:39 PM
*Boostwerks*
17
Feb 23, 2007 04:31 PM
DannyDeuce
Sep 8, 2006 03:46 PM
Excelerate
Oct 28, 2003 08:34 AM
Excelerate
Oct 27, 2003 07:18 AM
