LS motor
Old Jan 27, 2005 | 06:04 PM
sLoWrAcEr's Avatar
Default LS motor
i am planning on putting a LS into my 1993 civic si hatchback....what do i have to do with the vtec wires and stuff? what ecu should i run...thanx for all the info..yes i searched and couldnt find what i was exaclty talking about... thanx!
Old Jan 27, 2005 | 06:05 PM
sockvtec's Avatar
Default Re: LS motor (sLoWrAcEr)
the vtec will be useless on an ls motor, so just get rid of all the vtec realated crap, and i think you can run a chipped p28 if im not mistaken
Old Jan 27, 2005 | 06:19 PM
ralphie14's Avatar
Default Re: LS motor (zoomzoom92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zoomzoom92 &raquo;</TD></TR><TR><TD CLASS="quote">the vtec will be useless on an ls motor, so just get rid of all the vtec realated crap, and i think you can run a chipped p28 if im not mistaken</TD></TR></TABLE>
As far as I know you need a NON Vetc ECU a P28 will not work I think you need a P75 or P06 to chip.
Old Jan 27, 2005 | 06:52 PM
dantastic's Avatar
if you don't get a usdm harness with your motor, just re-use your stock harness and leave the vtec oil pressure switch and solenoid plugs un plugged. use a p74, p75 or pr4 obd1 ecu.
Old Jan 27, 2005 | 06:54 PM
white ex's Avatar
Default Re: LS motor (ralphie14)
you need a obd-1 p75, you should be able to just plug it in and not have to worry about any wiring.
Old Jan 27, 2005 | 07:41 PM
BDogggUT34's Avatar
Default Re: LS motor (white ex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white ex &raquo;</TD></TR><TR><TD CLASS="quote">you need a obd-1 p75, you should be able to just plug it in and not have to worry about any wiring.
exactly how it was for my swap!!
Old Jan 27, 2005 | 09:20 PM
blackeg's Avatar
Default Re: LS motor (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">
if you don't get a usdm harness with your motor, just re-use your stock harness and leave the vtec oil pressure switch and solenoid plugs un plugged. use a p74, p75 or pr4 obd1 ecu.</TD></TR></TABLE>
dont cut the vtec wiring out, just in case you need it for other reasons in the future
Old Jan 29, 2005 | 09:08 PM
sLoWrAcEr's Avatar
Default Re: LS motor (blackeg)
yes siirrr LS/vtec!
CRX_RR
Mar 1, 2008 09:54 PM
djtsmith007
Jun 12, 2007 05:44 PM
ls-v*2
Aug 12, 2006 07:27 AM
bmoresbest781
Aug 7, 2006 01:58 PM
Vtec92Civic
Oct 3, 2004 02:58 PM
