Help with vaccume
Old Jan 27, 2005 | 03:27 PM
crxhf19's Avatar
Default Help with vaccume
Does anyone have A pic or diagram of how my vaccume lines ned to be in my swap. i have an hf and i am putting in a B18a. thanks in advance
Old Jan 27, 2005 | 03:33 PM
crexer's Avatar
Default Re: Help with vaccume (crxhf19)
on my b16 swap I have 2 vacuum lines everything else was easily removed. 1 from the FPR to the nipple on the back of the intake manifold. 2 Map sensor to nipple on the throttle body. Charcoal canister, purge valves and any other junk, was removed. Throws no codes, idles fine, emissions friendly (i guess)
Old Jan 27, 2005 | 03:36 PM
crxhf19's Avatar
i appreciate your help but i am looking for the way that still uses all the factory stuff because i dont want any **** when i go to get it examined
Old Jan 27, 2005 | 04:38 PM
crxh22project's Avatar
Default Re: Help with vaccume (crexer)
where exactly is the Map sensor im currently on the same problem.
what nipple do use on the Throttle body, there is like 2 of them
Old Jan 27, 2005 | 05:14 PM
crexer's Avatar
Default Re: Help with vaccume (crxh22project)
i didnt realize tenn. had emmissions testing. Also i dont think the char can or purge valves make a difference. All that crap is useless. Make it easier on yourself and clean up the bay while your at it. Just my 2 cent.
Old Jan 28, 2005 | 05:40 PM
Which one is the map sensor?
where is it and where does it go.
Old Jan 28, 2005 | 08:13 PM
jlicrx's Avatar
here is where vacuum lines go on engine
here is what is inside the black box on the passenger side on the HF
civic-one
Aug 24, 2009 06:32 PM
chris3385
Jan 3, 2009 04:49 AM
LUKE 92 GS-R
Jun 18, 2008 06:17 PM
Hondamonster
Jun 9, 2007 04:35 AM
PearlBlueType-S
Jan 7, 2006 09:27 AM
