how does this happen?!?....wheel hop sucks!
Old Jan 27, 2005 | 02:53 PM
project-boosteD's Avatar
Default how does this happen?!?....wheel hop sucks!
so...im at the race track....first night its open after winter...
i line up....launch it....wheel hop like a son of a bitch...dash about falls off
hit 2nd gear...again...wheel hop like crazy
hit 3rd gear...again...wheel hop....but this time...it goes...CRACK!...
and i pop my hood to this....
the bottom bolt that u cant see....gone...completly broke off along with the casing that surrounds the bolt....top one just cracked...only held in there by a few threads...
oh and thats my rear torque mount for those who are a bit confused...
life sucks ***.....how does this happen?!?
Old Jan 27, 2005 | 03:10 PM
GDM Z28's Avatar
Default Re: how does this happen?!?....wheel hop sucks! (gsrcivic147)
same thing happened to me but the bottom holes ar stripped and the top is missing alittle chumk smaller than urs. i just threaded them in but they are loose. they seem to be holding so far ::knocks on wood::
Old Jan 27, 2005 | 04:42 PM
cnydc2's Avatar
That SUCKS!!!!!!!
Wheelhop SUCKS!!!!!!
Old Jan 27, 2005 | 10:26 PM
paopao's Avatar
Default Re: how does this happen?!?....wheel hop sucks! (cnydc2)
wheel hop comes from bad bushings. get motor mount inserts.
Old Jan 28, 2005 | 01:08 AM
TrnsferErr's Avatar
Default Re: how does this happen?!?....wheel hop sucks! (teal94cx)
is that your tranny?
Old Jan 28, 2005 | 02:36 AM
untitled's Avatar
Default Re: how does this happen?!?....wheel hop sucks! (TrnsferErr)
Wheel hop comes from bad EG/EK/DC Front crossmember design from the factory. I recommend a Titanium Lakewood traction bar. You can get them for $350 shipped right now from i think Titan Motorsports.
good luck tha loks nasty
Old Jan 28, 2005 | 04:31 AM
nsxmatt's Avatar
That does suck. Wheelhop is basicly a jackhammer on everything attached to the motor, including the mounts and axles. At least now you should know that wheel hop is bad and you should let off instead of letting it continue through 3 gears until something breaks
Old Jan 28, 2005 | 06:23 AM
ek9800's Avatar
Default Re: how does this happen?!?....wheel hop sucks! (nsxmatt)
that sucks man.
traction bar time.
Old Jan 28, 2005 | 01:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrnsferErr &raquo;</TD></TR><TR><TD CLASS="quote">is that your tranny? </TD></TR></TABLE>
yes....yes it is....hahaha
well i didn't think it would wheel hop all the way through 3rd gear....very *** though...
i've looked into the traction bar...very good deal
if anybody can see where it is...its right above the diff...anyone know how to fix that without havin to get a new tranny?
Old Jan 28, 2005 | 01:03 PM
untitled's Avatar
youd have to TIG a chunk of aluminum stock on the back of the tranny where the bolt threads are broke. Then drill it ou tand tap it with the proper tap. And use a bolt that accompanies the tap's thread properly.
Old Jan 28, 2005 | 01:34 PM
biotech0123's Avatar
Default Re: how does this happen?!?....wheel hop sucks! (untitled)
lsd and traction bars
Old Jan 29, 2005 | 09:29 AM
Default Re: how does this happen?!?....wheel hop sucks! (biotech0123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biotech0123 &raquo;</TD></TR><TR><TD CLASS="quote">lsd and traction bars</TD></TR></TABLE>
its a type r tranny...so it has lsd....unless the douche bag lied to me haha...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by untitled &raquo;</TD></TR><TR><TD CLASS="quote">youd have to TIG a chunk of aluminum stock on the back of the tranny where the bolt threads are broke. Then drill it ou tand tap it with the proper tap. And use a bolt that accompanies the tap's thread properly. </TD></TR></TABLE>
problems on its way to being fixed
preciate it
Old Jan 29, 2005 | 11:13 AM
paopao's Avatar
same exact thing happened to me recently. i just ended up replacing my old tranny w/type r tranny. you can always buy that half of the casing from honda. it's like 200 bucks.
Old Jan 29, 2005 | 03:18 PM
sabotage7's Avatar
biiiittttchhh! that sux!
i hope you get everything fixed soon! let us know if you get a traction bar and how that works out for you bc i may need one too!
Old Jan 29, 2005 | 08:21 PM
Default Re: how does this happen?!?....wheel hop sucks! (sabotage7)
i'll keep this post updated on repairs and what not....
im lookin into the traction bar....might be gettin it pretty soon here
GOTTA GET RID OF THIS DAMN WHEEL HOP!
Old Jan 29, 2005 | 08:38 PM
mmuller's Avatar
Mad Scientist
traction bars will help, but will not cure your severe wheel hop problems...
you should first look elsewhere to fix your problems; bushings-balljoints-motor mounts and such.
i use poly lower arm bushings and diy poly mounts and experience no wheelhop
Old Jan 30, 2005 | 09:02 AM
Default Re: how does this happen?!?....wheel hop sucks! (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">diy poly mounts </TD></TR></TABLE>
thats what im doin right now haha
waitin on the ***** to dry right now...
Old Feb 4, 2005 | 09:02 AM
SiFan's Avatar
Energy V's diy, I'll take energy any day. Also hasport has a solid mount for the EK now!
I dont know why you care at this point being that you are whithout lincense or soon to be DUMB *** STREET RACING FOOL!!! Watch out for that CRX!!!!
Old Feb 4, 2005 | 11:43 AM
Default Re: how does this happen?!?....wheel hop sucks! (SiFan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiFan &raquo;</TD></TR><TR><TD CLASS="quote">
I dont know why you care at this point being that you are whithout lincense or soon to be DUMB *** STREET RACING FOOL!!! Watch out for that CRX!!!! </TD></TR></TABLE>
that little bastard said he could beat john hodiak (300zx TT)....so i had to see what the deal was......he was a liein *** little ****.....
he got served....a lot
btw, who are u? haha
noname87
Mar 5, 2013 01:53 PM
EJ8VTEC
27
Aug 18, 2006 04:11 PM
rewerbcrx
15
Dec 24, 2005 07:50 PM
getnasty
35
Jun 15, 2005 02:50 PM
